Lag configuration question
  • Question
  • Updated 2 years ago
  • Answered
I have an S4 (main campus) with a lag on one end and I have three stacked B5's (remote campus) on the other.  They are connected via 1 mile long fiber.
Complaint from end user's has been poor internet speeds at the remote campus.  They are on a VLAN and come back via the fiber to go out through our internet provider.
I just started this job and am new to the extreme EOS though I just finished the bootcamp and passed the switching and routing exam.
I started to just look at the VLAN performance and noted it was terrible and I'm on main campus side.  I'm trying to document the existing switching design etc.  So I began to dig into how things are connected L1/L2.
I did notice though that I have two ports on the S4 setup as a LAG to the stacked B5's but on the stacked B5's there are NO LAGs configured.  Globally LACP is enabled on both ends but the stack hasn't been configured with a lag.
So first question is, how does this even work?  I thought that you had to have both ends configured properly for the LAG to work.  I know they can form automatically due to the global setting but I can't find anything on the B5's to indicate that has occurred.
Should I go ahead and setup the lag properly on each end with aadminkey's which one side appears to have already?
Port status shows the ports on the remote end to both be UP, all of the lag's appear as down this is the same as the main campus.
So it looks to me that the lag's are not configured and up properly and that neither end is setup.
Sorry for the long story but wanted to get some feed back on the situation. :)
Thoughts and suggestions are appreciated!
-Stephen
Photo of Stephen McGuire
Stephen McGuire
  • 1,012 Points 1k badge 2x thumb
  • amused...
Posted 2 years ago
Photo of Daniel Coughlin
Daniel Coughlin, Employee
  • 2,752 Points 2k badge 2x thumb
Stephen,
 I would suggest configuring the SecureStack side correctly.  Then use the show lacp commands to make sure it is the way you want it.  This article should guide you:How to Configure Dynamic LAGs with LACP on Securestack or Chassis based switches .  If you run into problems let us know.
Stephen McGuire
Thanks, I had most of the CLI already but that's a great link.
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
So, start with on the B5
show lacp lag.0.*
Does it show any ports in a LAG?
Do you have single port LAG turned on (Enabled)?
Also, run show  neighbors to confirm the uplink is what you think it is from both ends... if it is, check the ports for errors...
On the B5  show port counters ge.2.4
on the S4
show port counters errors nonzero
Are you seeing any errors on the ports or the supposed lag port?
Also, on the S4, for that particular problem VLAN.  run the command
show run int vlan.0.20
Paste the output here.
Stephen McGuire
The links are fiber links, can there be a hub on that port?  I don't think so, will have to head to the site and trace cables.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,636 Points 10k badge 2x thumb
Do you know what device sends a port name of "Gigabit Ethernet Frontpanel port 89" resp. "Gigabit Ethernet Frontpanel port 73"? Ip address 10.99.180.3 resp. 10.99.180.1? Does "show neighbors -verbose PORTSTRING" on the S4 provide useful information?
Stephen McGuire
On the S4 I believe only ge.2.112 and ge.3.112 are connected to the remote site via fiber.  I ran the -verbose command on the S4 and got the following output:
itsd-core1-S4(su)->show neighbors -verbose ge.2.112Port ge.2.112
  Neighbor                : 20-b3-99-3d-a9-8e
  System Name             : 180-OLD-COLONY
  Description             : SecureStack B5
  MTU                     : 0
  Last Update             : THU JAN 01 00:00:00 1970
  LLDP
    Chassis Id            : 20-b3-99-3d-a9-8e
    Port                  : ge.1.46
    Support               :
    Enabled               :
  CiscoDP
    Device Id             : 20b3993da98e
    Address               : 10.99.180.5
    Port                  : ge.1.46
    Version               : 2
    Primary Management    : 10.99.180.5
    Duplex                : Full Duplex
    Power                 : 0 milliwatts
    Support               : 0x0b01
  Neighbor                : 20-b3-99-3d-ae-c2
  System Name             : 162-OLD-COLONY-1
  MTU                     : 0
  LLDP
    Chassis Id            : 20-b3-99-3d-ae-c2
    Port                  : ge.1.48
    Support               :
    Enabled               :
  CiscoDP
    Device Id             : 20b3993daec2
    Address               : 10.99.162.12
    Port                  : ge.1.48
    Version               : 2
    Primary Management    : 10.99.162.12
    Support               : 0x0b01
  Neighbor                : 00-01-f4-61-34-00
  Description             : Matrix 1H582-51 : 03.07.30
  Port                    : Gigabit Ethernet Frontpanel port 81
  CDP
    Neighbor IP           : 10.99.180.1
    Chassis IP            : 10.99.180.1
    Chassis MAC           : 00-01-f4-61-34-00
    Device Type           : router
    Support               : igmp, rip, ospf, dvmrp, ieee8021q, gvrp
itsd-core1-S4(su)->show neighbors -verbose ge.3.112
Port ge.3.112
  Description             : Enterasys Networks, Inc. B5 -- Model B5G124-48P2 Rev
 06.81.04.0001
  Port                    : ge.1.47
  MTU                     : 0
  LLDP
    Port                  : ge.1.47
    Support               :
    Enabled               :
  CDP
    Neighbor IP           : 10.99.180.5
    Chassis IP            : 10.99.180.5
    Chassis MAC           : 20-b3-99-3d-a9-8e
    Device Type           : dot1qSwitch
    Support               : ieee8021q, gvrp, igmpSnoop
  CiscoDP
    Port                  : ge.1.47
    Version               : 2
    Support               : 0x0b01
OK, so the mystery device is an old Enterasys E1 switch.
I would assume the E1 does not understand CiscoDP or LLDP and thus floods it to the other ports (it's L2 multicast).
The E1 switch seems to be between the B5 stack and the S4, with other switches connected to it as well.
Stephen McGuire
I looked at that output several times and completely missed that. LOL
  • 13,772 Points 10k badge 2x thumb
As to why the configuration with a LAG on one end only can "work": EOS automatically falls back to using individual ports if no LACP PDUs are received or there are too few links to form the LAG (e.g. one link w/o singleportlag). Spanning tree will block redundant links and prevent a loop.
The LAG and individual port configurations can differ, so "work" should not be read as "work correctly".
Stephen McGuire
Ok, so here's what I found when I was able to get to the location:
B5 has port ge.1.47 connected to the the S4 via fiber to ge.3.112
E1 has port ge.3.1 connected to the S4 via fiber to ge.2.112
There is a link between the E1 ge.2.2 and the B5 ge.1.46 which explains the neighbor info.
Currently the spanning tree info shows the following:
SID   Port     State        Role        Cost       Priority
 0     ge.2.2   forwarding   designated  1          128
 0      ge.1.46      Discarding         Alternate     20000       128
So if I understand this correctly, there is no loop but the two fiber runs are not setup in a LAG configuration.
So my question is this, should I place both fiber runs on the B5, and lag them?  I have proposed that and included adding a 3rd fiber run to make a single 3GB lag between the B5 and S4 then have the E1 off the B5 stack (there's 3 switches).
Thoughts on that?  It's been approved but I could change it.  Fiber is already existing and the only financial cost is getting single mode gbic's and a patch cable (under $75 from amazon).
Would like to hear anyone's opinion's on that change in configuration, thanks.
-Stephen
Hi Stephen,
if you keep the direct connection between S4 and E1, you can reboot the B5 stack without losing connectivity to the remote campus. As such I would rather recommend to just add a new fiber link to the B5 stack, but keep the E1 connections.
I would recommend to enable CiscoDP and LLDP on the E1, or disable it on the respective S4 and B5 ports connecting to the E1.
According to an E1 manual for FW 3.07.xx the E1 supports CiscoDP, but not LLDP. So you should disable LLDP on the S4/B5 Ports connecting to the E1, and enable CiscoDP on the E1.
Thanks,
Erik
Stephen McGuire
Hello Erik, that's a really good consideration, something that made me think about what value that has and if it would really benefit us.  Without getting to deep in the details, I think the value of the 3gb pipe vs. the redundancy of the one E1 switch isn't sufficient enough to warrant keeping that connection.  The density of the office/classroom space has decreased to the point where we may be able to move most connections to the B5 stack and start removing some of the E1's.  We rely more and more on WiFi and the fe.*.* ports are just not even in use or have patch cords available in the spaces they occupy. But I like the way you think!
Assuming we go with the 3 connections as ONE lag for 3gb, is there any value is splitting them across the stack?  1st in #1, 2nd in #2 and 3rd in #3?  I thought it was mentioned as a best practice in my EOS bootcamp but my memory is fuzzy.
Thoughts?
-Stephen
Hi Stephen,
splitting the LAG links across the stack adds redundancy against one stack member failing, e.g. because of a defective PSU. This is similar to splitting LAG members across different modules in a chassis based switch.
Br,
Erik
Stephen McGuire
Excellent, our S4 only has two slots occupied plus we're nearly full so finding ports will be tough.  However the B5's won't be an issue to spread them around.
Great stuff thanks!
-Stephen
