Lag X460G2 CCR1009
Lag X460G2 CCR1009
Bruno
Hi, im having a issue while tring to bond 2 ports between a x460-g2 and a mikrotik ccr1009. My TX traffic get balanced but there is no way to balance RX.
I've tried using 802.3ad, L2, L3, L3_L4 and custom, with and without lacp, updated routerOS, but get no results.
This is
a923d645a758404da4157bed711ed130_RackMultipart20180627-65884-1ju24ml-CCR1009_Sharing_inline.jpg
Config for X460G2 and CCR1009 as follow:
a923d645a758404da4157bed711ed130_RackMultipart20180627-113973-1ljp83s-X460G2_Sharing_inline.jpg
a923d645a758404da4157bed711ed130_RackMultipart20180627-64366-1r9ompo-CCR1009_Config_inline.jpg
Thank you in advance 🙂
17 REPLIES 17
Eric_Burke
New Contributor III
As an add-on to one of the other responses. I believe the method of sharing is to run the appropriate type of connection (L2, L3_L4, etc.) through a hashing algorithm and then divide that value by the number of ports in the LAG. The modulo (remainder) is used to select the port (0 being the first port, 1 being the second, etc.). Since the modulo is always 0 or "1 less" than the total number of ports (since you divided by that), it's a pretty easy decision to make. Mathematically, without enough source/dest. combos, you could see a pretty big difference between one or the other.
Eric
Bruno
Ops, one more thing. Is there a way to configure round robin on x460? if yes, then how?
Bruno
Thank you;
Drew_C
Valued Contributor III
Round Robin is not supported.
