LAG in MLAG with LACP
  • Question
  • Updated 4 years ago
  • Answered
Create Date: Jul 25 2013 11:06PM
Hello,
I'm not sure about below config, in this moment i don't have switches to test this scenario so i'd like ask about check this config:2 core switches: summit670 (15.3) connected each other 4x10G ports: 45-481 switch edge: BD8810 (12.5) connected to each summit 2x10G ports 1-2 to summit1, ports 3-4 to summit2
conf:
summit1:
create vlan "isc"configure vlan isc tag 3000
configure vlan isc add ports 45 tagged
enable sharing 45 grouping 45-48 algorithm address-based L3_L4 lacp
enable sharing 1 grouping 1-2 algorithm address-based L3_L4 lacp
create mlag peer "mlag-to-summit2"
configure mlag peer "mlag-to-summit2" ipaddress 1.1.1.2 vr VR-Default
enable mlag port 1 peer "mlag-to-summit2" id 1
conf summit2:
create vlan "isc"
enable sharing 3 grouping 3-4 algorithm address-based L3_L4 lacp
configure mlag peer "mlag-to-summit1" ipaddress 1.1.1.1 vr VR-Default
enable mlag port 3 peer "mlag-to-summit2" id 3
bd:
enable sharing 1:1 grouping 1:1-4 algorithm address-based L3_L4 lacp
Is this config correct ?
thanks for help
regards,
Peter
(from peter_peter)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Aug 1 2013 10:12AM
Please next time try to cut properly config, I can't read that.MLAG and LAG (LACP) will work but there is one case with this configuration ( If You'll loses link for more then few minutes, it will not back to LAG group). So it's not supportet, use static LAG that works well.
(from karpiu)
