Laptops unable to connect to wireless
  • Problem
  • Updated 3 years ago
  • Solved
Our school district's Windows 7 laptops are unable to connect to the wireless with the "validate server certificate" setting enabled under the wireless properties. If I uncheck that box the laptop is able to connect. With about 1000 laptops unchecking that on all will be a pain. Would adding a certificate to the NAC solve this problem?
Photo of Kent Sapp
Kent Sapp
  • 260 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,044 Points 50k badge 2x thumb
Hi Kent,
as it isn't clear from your post my assumption is that ...
The Win7 laptop is connected to a SSID which is using 802.1X PEAP and is authenticated via the NAC which has a conenction to a databse (i.e. LDAP) to check the accounts.
Correct ? If not please let us know how the systems interwork which each other.
-Ron
Photo of Kent Sapp
Kent Sapp
Yes, that is correct.
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,994 Points 5k badge 2x thumb
Kent
You'll need to either deploy the CA certificate to the clients trusted certificate store or uncheck the validate server certificate box, which I think can be done via Group Policy definition.
The problem seems to be that the client can't match the server certificate as a trusted one, this is why it works when the client is told not to validate the server certificate it works.
This article might help: https://gtacknowledge.extremenetworks.com/articles/Solution/802-1x-User-PEAP-User-Rejected-in-NAC
-Gareth
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,710 Points 20k badge 2x thumb
Photo of Kent Sapp
Kent Sapp
Is there a was to export the current certificate in NAC so I can deploy it on a laptop?
Where is your root CA, if NAC is terminating 802.1X the certificate will be self signed and probably not what you want?
This article might help: https://gtacknowledge.extremenetworks.com/articles/How_To/How-To-Update-NAC-Internal-Communications-...
Photo of Kent Sapp
Kent Sapp
Just an update. We got a certificate from GoDaddy and added the wireless settings to a gpo. Our laptops are now connecting without issue. Thank you for all your advice.
Photo of Drew C.
Drew C., Community Manager
  • 40,686 Points 20k badge 2x thumb
Hi Kent, Thanks for coming back and updating the thread.  Glad to see you got it sorted out!
