Layer 2 vlan across Core/switches
  • Question
  • Updated 10 months ago
  • Answered
Hi
Think I'm being a bit stupid.   We have core switch (Extreme 670) attached to edge stacks (440s) and want to create a layer 2 Vlan across the network.
So the vlan is created on both the core switch and the edge switch, same tag ID and tagged between each others uplinks.    The endpoint is on the edge switch and the port that is physically connected is in the vlan.    I can see the mac address of the endpoint but not the IP.
So problem is a device not on the same edge stack which has the endpoint connected goes through the core switch but because the ip address of the endpoint is not broadcast the traffic just follows the default route on the core and fails.   I cannot ping the endpoint from the core.
How can I get round this problem and get the traffic to the endpoint but without layer 3 vlan?  It is for a security that I don't want layer 3.
Hope that makes sense.
Thanks
Jack
Photo of Jackson
Jackson
  • 80 Points 75 badge 2x thumb
Posted 10 months ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,484 Points 10k badge 2x thumb
Hello Jackson,
If I am understanding you correctly (Forgive me if I am missing something). It sounds like you are unable to see the IP address on the x440 through the "show iparp" command. If you do not have an IP address on the VLAN (You can have an IP address on the VLAN without allowing the specific switch to route that traffic) it will not display any ARP information. You should be bale to grab this information form the Core considering it should have an IP address applied to the VLAN.
Photo of Jackson
Jackson
Thank you for the reply. I will give this a try.
Thanks again.
