LDAP authentication issue
  • Problem
  • Updated 5 months ago
  • Solved
Hello all.
I am having some issues getting LDAP based auth to work in the captive portal. The LDAP-agent is configured and joined the domain. I have a group in AD with some users for wireless access. I have went through the documentation and videos on youtube with no luck.
Here is the log:
Jun 14 10:32:48 2018: %DAEMON-3-ERR: radiusd[7278]:   [ldap_primary] LDAP login failed: check identity, password settings in ldap section of radiusd.confJun 14 10:32:48 2018: %DAEMON-3-ERR: radiusd[7278]:   [ldap_primary] (re)connection attempt failed
Jun 14 10:32:48 2018: %DAEMON-5-NOTICE: radiusd[7278]: Invalid user: [danielst] (from client localhost port 1 cli 5C-AF-06-4C-35-12)
Everything seems to be setup correctly. Any of you went through this issue before and can offer some advice?
Thanks, DS
Photo of Daniel Starosciak
Daniel Starosciak
  • 390 Points 250 badge 2x thumb
Posted 5 months ago
Photo of Alona
Alona, Employee
  • 1,770 Points 1k badge 2x thumb
Is this WING5.9.2? are you using PAP authenticaiton?
Daniel Starosciak
We are running WING 5.8.6.5. Authentication is MS-CHAPv2.
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 6,102 Points 5k badge 2x thumb
Daniel,
could you raise a support case with us using Extreme Portal and post running configuration so we can check it?
Regards,
Ondrej
Daniel Starosciak
Just an update that I got this working. I misconfigured the bind dn in the LDAP section. Even when misconfigured, it was showing as joined the domain.
