Legacy Firmware for 1i
  • Question
  • Updated 3 years ago
  • Answered
We pulled from inventory a working 1i.   It has
System Serial Number: 800084-09-0139M00658
Image  :  Extremeware Version 6.1.5 (Build 20)  by Release_Master  Sat 09/23/2000  6:56p
Our upgrade path is
To upgrade EW I-Series switches to 7.1.0, you have to follow the below upgrade path:
Upgrade the BootROM to Version 8.2  - I-Series_ngboot82.bin
Upgrade to ExtremeWare 6.1.9  - I_Series_v619b41.xtr
Upgrade to ExtremeWare 6.2.2.56 - I_Series_v622b134.Sxtr
Upgrade to ExtremeWare 7.1.0 - I_Series_v710b48.Sxtr
The items in bold I am unable to locate. On our network we have 5000+ extreme devices, but in our archives I am unable to find this older firmware, searches of google and Extreme support produced no results. Where would I find them?
Photo of Jimmy
Jimmy
  • 650 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
Hi Jimmy,
It's been a while since I've had to think about the upgrade path for the 1i - what you've listed here sounds correct.
Since this switch is quite old and not all of the files are easily available, I went ahead and packaged the ones you requested (or an equivalent and compatible version) for you to use.
http://tech.extremenetworks.com/ftp/ftp_new.aspx?file=1i_upgradefiles.zip
In the zip file, you'll also find the most recent (and last) ExtremeWare release, v784b1-patch1-4.  The Summit 1i in this release uses Bxtr files (instead of xtr), so I included those for you.  No guarantees that it will work, but we can try!
Good luck!
-Drew
Photo of Jimmy
Jimmy
Drew, you freakin rock.....thank you!
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Wow Jimmy....love the size of your purple network and that your 1i is still rocking.  Impressive.
I'm curious, how long has it been in service?  This is almost a truck testimonial where the owner has driven 400,000 miles...good stuff!
(Edited)
Photo of EtherMAN
EtherMAN, Embassador
  • 6,960 Points 5k badge 2x thumb
I'll match his 1I with a couple of summit 24's that have been in place since around 1999... Still making us money... I would imagine Jimmy has more than just the 1i in his lineup too... Just can't seem find a reason to replace things that still work and do their jobs.
Ryan Mathews, Alum
That is impressive!  Those early Summit(s) -- 24 & i-Series -- were rock solid.  Love to see that they're still cranking today.
Thanks for sharing EtherMAN and Jimmy!
