Link Fault Signal
  • Question
  • Updated 4 years ago
  • Answered
I have a query regarding Link Fault Signal Function.
What determines a local/remote fault on a port when it goes down.
Am I to assume that a local fault means the switch caused the port to go down and a remote fault, the client caused the port to go down?
The concepts guide is non existent when it comes to explaining the reasoning's for this.
Look forward to your response
Photo of Ian Broadway
Ian Broadway
  • 1,552 Points 1k badge 2x thumb
Posted 4 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Official Response
Hello Ian
This is part of the IEEE 802.3ae-2002.  If you search on that site it will explain the difference.  Essentially it is whether the port detects the link fault on its TX or RX pair.
Let me know if that helps.
P
