linkflap not workings
  • Problem
  • Updated 4 years ago
Have a S8 that has multiple 10Gb mm fibre ports that are Flapping like crazy - issue to do with with poor cables currently being investigated.
Problems is that no matter what I configure the linkflap paramenters to be I can not get the currentcount to increment and linkflap to generate an action, even though the port is clearly going linkdown and linkup. You can see this in this on the console, Netsight traps and topology changes.
The changes are occurring roughly every second or mutlples of seconds. Sample of the config below where I've tweaked the settings to 2 actions in 60 seconds to give more than big enough scope to capture an event:
show version
Copyright (c) 2011 by Enterasys Networks, Inc.
Slot    Model             Serial #              Versions
1       SK1008-0816       xxxxxxxxxxxxx         Hw: 3
                                                Bp: 01.01.00
                                                Fw: 07.41.02.0014
2       SK1008-0816       xxxxxxxxxxxx          Hw: 3
                                                Bp: 01.01.00
                                                Fw: 07.41.02.0014
3       SK1008-0816       xxxxxxxxxxxxx         Hw: 3
                                                Bp: 01.01.00
                                                Fw: 07.41.02.0014
4       SK5208-0808-F6    xxxxxxxxxxxx          Hw: 6
                                                Bp: 01.01.00
                                                Fw: 07.41.02.0014
5       SG5201-0848-F6    xxxxxxxxxxxx          Hw: 6
                                                Bp: 01.01.00
                                                Fw: 07.41.02.0014
show linkflap globalstate
Linkflap feature globally enabled
show linkflap parameters tg.4.7
Linkflap Port Settable Parameter Table (X means error occurred)
Port      LF Status  Actions  Threshold   Interval    Downtime
tg.4.7    enabled    D..S..T  2           60          300
show linkflap metrics tg.4.7
Linkflap Port Observables Table (X means error occurred)
Port      LinkStatus   CurrentCount  TotalCount  TimeElapsed  Violations
tg.4.7    operational  0             7           1117         0
Many thanks.
Photo of Martin Flammia
Martin Flammia
  • 6,326 Points 5k badge 2x thumb
Posted 4 years ago
Be the first to post a reply!
