LLDP not working for polycom, but working for Cisco phones on x460-G2
  • Problem
  • Updated 10 months ago
  • Solved
We have two phones, one Polycom VVW310 and a Cisco 7911 plugged into sequential ports on our stack.  They are configured with the same LLDP configuration and the Cisco joins the proper voip network while the polycom does not.  In the neighbor details, the only difference seems to be in the policy section.  The polycom shows "unknown policy" and the cisco shows "known policy".  Any ideas?
LLDP Port 1:15 detected 1 neighbor
  Neighbor: (5.1)0.0.0.0/00:04:F2:8C:4F:5D, age 59 seconds
    - Chassis ID type: Network address (5); Address type: IPv4 (1)
      Chassis ID     : 0.0.0.0
    - Port ID type: MAC address (3)
      Port ID     : 00:04:F2:8C:4F:5D
    - Time To Live: 120 seconds
    - Port Description: "1"
    - System Name: "Polycom VVX 310"
    - System Description: "Polycom;VVX-VVX_310;3111-46161-001,2;SIP/4.1.8.06\
                           28/30-Sep-14 00:40;UP/5.1.8.0598/30-Sep-14 01:08;"
    - System Capabilities : "Bridge, Telephone"
      Enabled Capabilities: "Telephone"
    - IEEE802.3 MAC/PHY Configuration/Status
      Auto-negotiation       : Supported, Enabled (0x03)
      Operational MAU Type   : 1000BaseTFD (30)
    - MED Capabilities: "MED Capabilities, Network Policy, Extended Power via MDI - PD, Inventory"
      MED Device Type : Endpoint Class III (3)
    - MED Network Policy
      Application Type  : Voice (1)
      Policy Flags      : Unknown Policy, Untagged (0x0)
      VLAN ID           : 0
      L2 Priority       : 5
      DSCP Value        : 46
      Application Type  : Voice Signaling (2)
      VLAN ID           : 0
      L2 Priority       : 5
      DSCP Value        : 44
    - MED Extended Power-via-MDI
      Power Type    : PD Device (1)
      Power Source  : PSE and Local (3)
      Power Priority: Unknown (0)
      Power Value   : 5.0 Watts
    - MED Hardware Revision: "3111-46161-001,2"
    - MED Firmware Revision: "UP/5.1.8.0598/30-Sep-14 01:08"
    - MED Software Revision: "SIP/4.1.8.0628/30-Sep-14 00:40"
    - MED Serial Number: "0004f28c4f5d"
    - MED Manufacturer Name: "Polycom"
    - MED Model Name: "VVX-VVX_310"
    - MED Asset ID: ""
LLDP Port 1:16 detected 1 neighbor
  Neighbor: (5.1)10.91.0.30/002584178E5F:P1, age 24 seconds
      Chassis ID     : 10.91.0.30
    - Port ID type: Locally assigned (7)
      Port ID     : "002584178E5F:P1"
    - Time To Live: 180 seconds
    - Port Description: "SW PORT"
    - System Name: "SEP002584178E5F"
    - System Description: "Cisco IP Phone CP-7911G,V8, SCCP11.8-4-4S"
      Enabled Capabilities: "Bridge, Telephone"
    - Management Address Subtype: IPv4 (1)
      Management Address        : 10.91.0.30
      Interface Number Subtype  : Unknown (1)
      Interface Number          : 0
      Object ID String          : "null"
      Operational MAU Type   : 100BaseTXFD (16)
      Policy Flags      : Known Policy, Tagged (0x1)
      VLAN ID           : 900
      L2 Priority       : 5
      DSCP Value        : 46
      VLAN ID           : 900
      L2 Priority       : 4
      DSCP Value        : 32
      Power Source  : Unknown (0)
    - MED Hardware Revision: "8"
    - MED Firmware Revision: "tnp11.3-0-1-32.bin"
    - MED Software Revision: "SCCP11.8-4-4S"
    - MED Serial Number: "FCH132097PD"
    - MED Manufacturer Name: "Cisco Systems, Inc."
    - MED Model Name: "CP-7911G"
    - MED Asset ID: ""
Photo of Eric Burke
Eric Burke
  • 2,426 Points 2k badge 2x thumb
Posted 3 years ago
Photo of Eric Burke
Eric Burke
Bump - anyone have any ideas?
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,562 Points 10k badge 2x thumb
I'm not an expert with LLDP-MED related configuration, but let me try to share my ignorance.
Can you please capture what the phone/switch are sending? googling a bit I have read a few issues with Polycom and the presence of optional TLV set to null. It would be interesting to check that first.
Can you paste the LLDP config as well?
and Merry Christmas!
Photo of Eric Burke
Eric Burke
I will take a look after the holiday when the client returns.  The configuration is the "standard" suggested by Extreme in several posts here on the hub and in technotes.  Nothing fancy...  Polycom just seems to stay on the default VLAN no matter what.  I'll grab the trace and upload after the new year.  Thanks for the offer of assistance. I too am not an LLDP expert and not sure where else to look...
Do you have new information about that? I have the same issue.
Photo of Anderson Vaughan
Anderson Vaughan, Employee
  • 298 Points 250 badge 2x thumb
There was a similar issue on the Polycom VVX 410 VoIP phone, see the following article:-
https://gtacknowledge.extremenetworks.com/articles/Solution/Polycom-VoIP-Phone-not-obtaining-DHCP-IP...
Photo of Paul Schofield
Paul Schofield
  • 60 Points
http://support.polycom.com/content/dam/polycom-support/products/Voice/business_media_phones/user/en/...
This is covered under the "Configuring LLDP Fast Start Count" section in the above document link from Polycom
