load mib to A2H124
  • Question
  • Updated 3 years ago
  • Answered
Hi community,
we have a switch A2H124-48P  which is not sending snmp traps when a cable is unplugged. I used snmpwalk and found that the O.I.D. .1.3.6.1.6.3.1.1.5.3 is not responding (IF-MIB). This OID is responsible for sending the trap. I have seen in documents that the IF-MIB is supported by A2 series switch but in our case, it is missing. Is there a way to load it on the switch? Is it a matter of firmware?(current version   Rev 02.01.10.0001)
Photo of Nikos Tsachalis
Nikos Tsachalis
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of JAMES WIEDEL
JAMES WIEDEL
  • 780 Points 500 badge 2x thumb
Nikos,
The OID you sent is for the trap itself and you can not poll it.
Do you get *any* traps from the switch?    If not, you need to check your SNMP configurations.
In particular
show snmp notify
show snmp targetaddr
show snmp targetparams
which control the traps.
I am assuming SNMP in general works.
You could try loading "new" code into the switch.    I was looking at an A2 with version
03.03.02.0002 which you should be able to download from the Extreme support site.
It will be hiding in the Legacy gear section.
   James
Nikos Tsachalis
You are right , I shouldn't expect this oid to respond since it is a trap.
Photo of Ricardo Barroso
Ricardo Barroso
  • 60 Points
Gentlemen, what are the MIBs that I need to monitor the status of the stack?
Senhores, quais são as mibs que eu preciso para monitorar o status do empilhamento do A2H124
(Edited)
