Load MIBS and TRAPS over NetSight differents Brands
  • Problem
  • Updated 2 years ago
  • Solved
  • (Edited)
I need to load the MIBs and traps of different brands , what is the procedure for loading in NetSight and to have all the information the device?
Photo of Jairo Rojas Herrera
Jairo Rojas Herrera
  • 1,452 Points 1k badge 2x thumb
Posted 2 years ago
Jairo Rojas Herrera
Photo of Tony Thornton
Tony Thornton, Extreme Alumnus
  • 1,412 Points 1k badge 2x thumb
Hi Jairo,
Below is a link to a knowledgebase article that shows how to import MIBs into NetSight.
https://gtacknowledge.extremenetworks.com/articles/How_To/Netsight-Importing-a-MIB-into-Netsight
Hope this helps.
Tony
Jairo Rojas Herrera
THKS
Jairo Rojas Herrera
And download the MIBs and the load on the server of NetSight but as I do for loading or asosiarlas the device?
There are some technical guidance as asosiar the MIB with devices of different brands in NetSight ?
(Edited)
You should not need to associate a MIB with a particular device.  Have you tested that the MIB is correctly loaded by entering an OID in the "Find what" field?
  • In the 'Find What' field about half way down on the left enter a MIB Object from the MIB that you were trying to import. Click on Find. This will confirm the MIB was imported properly, if you are taken to that location in the MIB Tree then the MIB was imported successfully.
