Load sharing (lacp)
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
If I have load sharing enabled on 1:4,2:4 with 1:4 as master.
Do I need to put all vlans as tag on both 1:4 and 2:4
Or should I allow all vlans as tag on only master port 1:4
1:4,2:4 are ports of one core connecting to other core 1:4,2;4.
Photo of Sai Prasad Rao Rapolu
  • 1,494 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hello Sai
Once you have a Load share enabled you just add the master port to the VLAN.  The other ports will not show up.
Hope that helps
P
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Could you please share the output for the command below on both core-a and core-b:
show configuration | include sharing
show sharing
Core-A:
enable sharing 1:4 grouping 1:4, 2:4 algorithm address-based L2 lacp
Core-B:
Photo of Paul Russo
Paul Russo, Alum
Hello Sai
Those are the correct commands.  can you share the output you saw when it shows 1:4 tagged on one core and 1:4,2:4 on the other switch?
Also can you do a show port 1:4,2:4 info detail on both switches and post it?
Thanks
P
Core-A
-> show ports sharing Load Sharing Monitor
Config    Current    Agg       Ld Share    Ld Share  Agg   Link    Link Up
Master    Master     Control   Algorithm   Group     Mbr   State   Transitions
   1:4    1:4        LACP      L2          1:4        Y      A        1
                               L2          2:4        Y      A        1
Link State: A-Active, D-Disabled, R-Ready, NP-Port not present, L-Loopback
Load Sharing Algorithm: (L2) Layer 2 address based, (L3) Layer 3 address based
Core-B
                               L2          2:4        Y      A        1
THIS LOOKS good may be I was seeing some other config,
Photo of Paul Russo
Paul Russo, Alum
I agree it looks like a valid config.  If you do a show VLAN for the ones tagged on those ports you should just see port 1:4 added as tagged with a little g showing it is shared.  If that is the case I think you are fine.
P
Photo of Balaji Kumar Navaneethapandian
Balaji Kumar Navaneethapandian, Employee
  • 260 Points 250 badge 2x thumb
You need to associate master port 1:4 alone to all vlans.
