Login failed through SNMPv3 - wrong digest
  • Problem
  • Updated 7 months ago
  • Solved
Hi
Have an issue where each of the core switches in the network are continually reporting this error in the logs:
<Warn:SNMP.Master.AuthFail> Login failed through SNMPv3 - wrong digest  (10.23.23.12)
<Warn:SNMP.Master.AuthFail> Login failed through SNMPv3 - wrong digest  (10.23.23.142)
Those IP addresses listed (10.23.23.12 & 142) are NAC appliances. None of the core switches are configured in NAC switches configuration.
The SNMP configuration on the core switch looks like the following:
configure snmpv3 delete user "admin" engine-id 80:00:07:7c:03:00:04:96:9a:6a:54
configure snmpv3 delete user "initial" engine-id 80:00:07:7c:03:00:04:96:9a:6a:54
configure snmpv3 delete user "initialmd5" engine-id 80:00:07:7c:03:00:04:96:9a:6a:54
configure snmpv3 delete user "initialsha" engine-id 80:00:07:7c:03:00:04:96:9a:6a:54
configure snmpv3 delete user "initialmd5Priv" engine-id 80:00:07:7c:03:00:04:96:9a:6a:54
configure snmpv3 delete user "initialshaPriv" engine-id 80:00:07:7c:03:00:04:96:9a:6a:54
configure snmpv3 delete group "v1v2c_ro" user "v1v2c_ro" sec-model snmpv1
configure snmpv3 delete group "v1v2c_rw" user "v1v2c_rw" sec-model snmpv1
configure snmpv3 delete group "v1v2c_ro" user "v1v2c_ro" sec-model snmpv2c
configure snmpv3 delete group "v1v2c_rw" user "v1v2c_rw" sec-model snmpv2c
configure snmpv3 delete group "admin" user "admin" sec-model usm
configure snmpv3 delete group "initial" user "initial" sec-model usm
configure snmpv3 delete group "initial" user "initialmd5" sec-model usm
configure snmpv3 delete group "initial" user "initialsha" sec-model usm
configure snmpv3 delete group "initial" user "initialmd5Priv" sec-model usm
configure snmpv3 delete group "initial" user "initialshaPriv" sec-model usm
configure snmpv3 delete access "admin" sec-model usm sec-level priv
configure snmpv3 delete access "initial" sec-model usm sec-level noauth
configure snmpv3 delete access "initial" sec-model usm sec-level authnopriv
configure snmpv3 delete access "v1v2c_ro" sec-model snmpv1 sec-level noauth
configure snmpv3 delete access "v1v2c_ro" sec-model snmpv2c sec-level noauth
configure snmpv3 delete access "v1v2c_rw" sec-model snmpv1 sec-level noauth
configure snmpv3 delete access "v1v2c_rw" sec-model snmpv2c sec-level noauth
configure snmpv3 delete access "v1v2cNotifyGroup" sec-model snmpv1 sec-level noauth
configure snmpv3 delete access "v1v2cNotifyGroup" sec-model snmpv2c sec-level noauth
configure snmpv3 delete mib-view "defaultUserView" subtree 1.0
configure snmpv3 delete mib-view "defaultUserView" subtree 1.3.6.1.6.3.16
configure snmpv3 delete mib-view "defaultUserView" subtree 1.3.6.1.6.3.18
configure snmpv3 delete mib-view "defaultUserView" subtree 1.3.6.1.6.3.15.1.2.2.1.4
configure snmpv3 delete mib-view "defaultUserView" subtree 1.3.6.1.6.3.15.1.2.2.1.6
configure snmpv3 delete mib-view "defaultUserView" subtree 1.3.6.1.6.3.15.1.2.2.1.9
configure snmpv3 delete mib-view "defaultNotifyView" subtree 1.0
configure snmpv3 delete community "private"
configure snmpv3 delete community "public"
configure snmpv3 add user "NetSight" engine-id 80:00:07:7c:03:00:04:96:9a:6a:54 authentication sha auth-encrypted localized-key 23:ad:23:b8:23:cd:4c:23:f3:66:35:23:05:30:23:09:60:55:79:23:92:23:ea:44:4d:35:23:cd:23:82 privacy aes 128 privacy-encrypted localized-key 23:cb:58:23:9e:51:23:b0:45:23:d9:6c:23:c1:23:cc:23:86:23:f3:23:eb:23:b3:23:d2:6d
configure snmpv3 add user "NetSight" engine-id 80:00:1f:88:80:2f:51:09:53:4c:29:33:57 authentication sha auth-encrypted localized-key 23:aa:23:1a:23:a6:23:a6:65:23:ae:53:23:c5:47:23:c3:23:b6:33:38:46:30:23:b8:25:34:23:1f:23:d1 privacy aes 128 privacy-encrypted localized-key 23:0e:23:1d:23:f6:23:a5:48:23:ed:23:bf:23:de:23:f5:23:11:5f:23:09:23:8d:27:23:90:23:ea
configure snmpv3 add group "NetAdmin" user "NetSight" sec-model usm
configure snmpv3 add access "NetAdmin" sec-model usm sec-level priv read-view "defaultAdminView" write-view "defaultAdminView" notify-view "defaultAdminView"
configure snmpv3 add target-addr "TV1NetSight" param "TV1NetSight" ipaddress 10.23.23.20 transport-port 162 from 10.255.0.3 vr "VR-Default" tag-list "TVTrapTag"
configure snmpv3 add target-params "TV1NetSight" user "NetSight" mp-model snmpv3 sec-model usm sec-level priv
configure snmpv3 add notify "TVInformTag" tag "TVInformTag" type inform
configure snmpv3 add notify "TVTrapTag" tag "TVTrapTag"
disable snmp access snmp-v1v2c
disable snmpv3 default-group
disable snmpv3 default-user
disable snmp access vr "VR-Mgmt"
Little overkill, but generally just using SNMPv3 which works fine just for traps to be sent to 10.23.23.20, which is Extreme Management.
When I take a packet trace from the NAC appliance (10.23.23.12) I get the following:
Frame 6: 294 bytes on wire (2352 bits), 294 bytes captured (2352 bits)
Ethernet II, Src: ExtremeN_9a:6a:17 (00:04:96:9a:6a:17), Dst: Vmware_3a:43:d0 (00:0c:29:3a:43:d0)
Internet Protocol Version 4, Src: 10.255.0.2, Dst: 10.23.23.20
    0100 .... = Version: 4
    .... 0101 = Header Length: 20 bytes (5)
    Differentiated Services Field: 0x00 (DSCP: CS0, ECN: Not-ECT)
    Total Length: 280
    Identification: 0x0000 (0)
    Flags: 0x02 (Don't Fragment)
    Fragment offset: 0
    Time to live: 64
    Protocol: UDP (17)
    Header checksum: 0x0daa [validation disabled]
    Source: 10.255.0.2
    Destination: 10.23.23.20
    [Source GeoIP: Unknown]
    [Destination GeoIP: Unknown]
User Datagram Protocol, Src Port: 56970 (56970), Dst Port: 162 (162)
    Source Port: 56970
    Destination Port: 162
    Length: 260
    Checksum: 0xdf2c [validation disabled]
    [Stream index: 0]
    msgVersion: snmpv3 (3)
    msgGlobalData
        msgID: 508
        msgMaxSize: 8192
        msgFlags: 03
            .... .0.. = Reportable: Not set
            .... ..1. = Encrypted: Set
            .... ...1 = Authenticated: Set
        msgSecurityModel: USM (3)
    msgAuthoritativeEngineID: 8000077c030004969a6a17
        1... .... = Engine ID Conformance: RFC3411 (SNMPv3)
        Engine Enterprise ID: Extreme Networks (1916)
        Engine ID Format: MAC address (3)
        Engine ID Data: MAC address: ExtremeN_9a:6a:17 (00:04:96:9a:6a:17)
    msgAuthoritativeEngineBoots: 42
    msgAuthoritativeEngineTime: 602683
    msgUserName: NetSight
    msgAuthenticationParameters: bc5ee08e1e5cc1d2b2d1a5c9
        [Authentication: OK]
            [Expert Info (Chat/Checksum): SNMP Authentication OK]
    msgPrivacyParameters: 00000000000098e6
    msgData: encryptedPDU (1)
        encryptedPDU: 8412a3dd665bcdaf76713921a83bafac03569062096d8789...
            Decrypted ScopedPDU: 3081a5040b8000077c030004969a6a170400a78193020201...
                contextEngineID: 8000077c030004969a6a17
                contextName:
                data: snmpV2-trap (7)
                    snmpV2-trap
                        request-id: 424
                        error-status: noError (0)
                        error-index: 0
                        variable-bindings: 6 items
                            1.3.6.1.2.1.1.3.0: 60283163
                                Object Name: 1.3.6.1.2.1.1.3.0 (iso.3.6.1.2.1.1.3.0)
                                Value (Timeticks): 60283163
                            1.3.6.1.6.3.1.1.4.1.0: 1.3.6.1.6.3.1.1.5.5 (iso.3.6.1.6.3.1.1.5.5)
                                Object Name: 1.3.6.1.6.3.1.1.4.1.0 (iso.3.6.1.6.3.1.1.4.1.0)
                                Value (OID): 1.3.6.1.6.3.1.1.5.5 (iso.3.6.1.6.3.1.1.5.5)
                            1.3.6.1.4.1.1916.1.1.1.30.0: 10.23.23.12
                                Object Name: 1.3.6.1.4.1.1916.1.1.1.30.0 (iso.3.6.1.4.1.1916.1.1.1.30.0)
                                Value (IpAddress): 10.23.23.12
                            1.3.6.1.4.1.1916.1.1.1.50.0:
                                Object Name: 1.3.6.1.4.1.1916.1.1.1.50.0 (iso.3.6.1.4.1.1916.1.1.1.50.0)
                                Value (Integer32): 1
                            1.3.6.1.4.1.1916.1.1.1.51.0: 0a17170c
                                Object Name: 1.3.6.1.4.1.1916.1.1.1.51.0 (iso.3.6.1.4.1.1916.1.1.1.51.0)
                                Value (OctetString): 0a17170c
                            1.3.6.1.4.1.1916.1.1.1.52.0: 56522d44656661756c74
                                Object Name: 1.3.6.1.4.1.1916.1.1.1.52.0 (iso.3.6.1.4.1.1916.1.1.1.52.0)
                                Value (OctetString): 56522d44656661756c74
So the packet is from the core switch itself on IP 10.255.0.2 to NetSight on 10.23.23.20 as you expect.
What I don't understand are the OIDs showing authentication failures to the NAC IP of 10.23.23.12 using SNMPv2-trap?
I'm not sure why that's being sent by the switch?
This is the packet capture I was running on the NAC device 10.23.23.12:
tcpdump -vvv -i eth0 port 162 -w snmp.pcap
The only packets it collects are similar to the one shown above.
Any ideas?
Many thanks in advance
Photo of Martin Flammia
Martin Flammia
  • 6,326 Points 5k badge 2x thumb
Posted 7 months ago
Photo of Ahmed Haroun
Ahmed Haroun
  • 962 Points 500 badge 2x thumb
I think this is related to IP Router Discovery part of NAC IP resolution.
NAC will connect to the default gateway to try to resolve the IP of the end system, and i think it will use port 161 not 162 , 162 is the port used for SNMP trap.
Martin Flammia
Hi Ahmed,
Thanks for posting.... think you might be spot on there!
Should have captured on 161 and I might have seen and understood the request from NAC :)
Checked the setting and was set too --Use Switch SNMP Credentials--, so changed it to match the actual credentials I use for the switches, and as of yet not see this message popup in the logs.
Nice one, thanks for the help :)
Ahmed Haroun
you welcome , i have been wondering similarly earlier :)
glad i was able to help.
