Loop port shutdown
  • Question
  • Updated 3 years ago
  • Answered
Hi everyone,
I'm using x460 and x450, so, i have enabled the stp/rstp on the switch to guard against loop network and mainly access ports, where i need avoid the maximun  security level  about loop that can be happening in the customer network.
So, i have tried the feature stp, and work but i need is, when the port received some packet looped the port change to blocked mode, however when happens i need this port be disable and enable after x period, kind 10 minutes, then, is there any way to do this?
Tks
Photo of welisson
welisson
  • 908 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,016 Points 5k badge 2x thumb
Hello... The ultimate way to achieve this is to use ELRP and leave off STP, too messy and too much overhead. With ELRP you can see loops and either disable ports permanantly or for a specific time as you would like. Take a look in the xos concepts guide for examples of configuration. If you need more info please let me know.
Bill
Photo of welisson
welisson
Hi Bill,
Tks for your reply, i set this protocol at the specific port and work fine, however i would like to ask a question about this, where i saw at the concepts guide, it speaks about elsm wil be any thing like stp, but i don't understand better about it, so, the question is, is feature necessary to implement join elrp?
tks
