Loop Problem
  • Problem
  • Updated 3 years ago
  • Solved
Hello folks,
I need interconnect many extreme Switch, when try to connect Sw1 and Sw2, (See picture), A broadcast storm block both Switchs, I have many Vlans and the ports are in trunk Mode.
Which is the  way to interconnect two Extreme Switch, I need LACP?. The STP is disabled.
Thanks in advance for your Help
Photo of Uber Londono
Uber Londono
  • 320 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Michael Kirchner
Michael Kirchner
  • 1,846 Points 1k badge 2x thumb
From my point of view you need STP. Maybe EAPS (Ring Topology) could be a solution, depends on the scenario. What Switch is the Core Switch? Also Extreme? What type?
And Why do you want a interconnect of SW1 and SW2 with all the VLANS? Do you want to avoid downtime if the core fails or what is your idea behind this?
Best Regards
Michael
Uber Londono
Thanks Michael for reply,
The core switch is a Cisco 6509, I need connect Sw1 and Sw2 because do not have an Advanced Edge Licence and Sw1 is Default Gateway for servers in my Vlans.
One question more, if I have a VRRP Licence don ́t have to connect SW1 and SW2, right?
Thanks again
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
PVST+ in extreme should be the best solution with cisco.
Photo of Kawawa
Kawawa, GTAC
  • 3,292 Points 3k badge 2x thumb
You can configure an ERPS ring between the Cisco switch, SW1 and SW2 as ERPS is an open standard.  You can then configure the Link between SW1 and SW2 to be your blocking port.  That should take care of your storm.  Let me know if you need configuration examples.
Uber Londono
Thanks Kawawa,
Yes please I need some Examples, The ERPS ring will be, between Cisco and SW1 and SW2?, The Cisco administrator need do something in your device?.
Thanks
Photo of Kawawa
Kawawa, GTAC
Hi, this is how you would generally configure your ERPS ring.  I'd advise you reference the XOS User Guide that's available on the Extreme Website from page 1029 onward.  Otherwise, the below configuration is the basic ERPS setup
create vlan <control-vlan> tag <id>
create vlan <protected-vlan> tag <id>
You'll need to add your control ports that will handle East and West traffic in the ERPS ring to your Control VLAN
create erps <ring-name>
configure erps <ring-name> add control <vlan>
configure <ring> add protected <vlan>
configure <ring> protection-port <port>
configure <ring> ring-port east <port>
configure <ring> ring-port west <port> enable erps <ring-name> enable erps
 You'll do something similar on all three switches making sure all you ring ports can communicate with each other. If this is a little cumbersome, you can configure an MLAG/vPC as Marco has outlined below. Regards
Photo of Marco Lorenz
Marco Lorenz
  • 694 Points 500 badge 2x thumb
I World try to configure the Ports on Cisco to Sw1 and Sw2 as a LinkAggregationGroup. Sw1 and Sw2 will build a MLAG with their Ports to the core. MLAG is a "Virtual LAG" between Ports of two non-Stacked Switches The Interconnection beteten Sw1 and Sw2 will be the so called ISC. Once you have configured MLAG correctly you will be able to connect your Servers redundantly to Sw1 and SW2 with their Ports configure as MLAG-PAIR.
Another solution Would be to build a Stack out of Sw1 and Sw2. In this case the link between Sw1 and Sw2 will be the stackingcabe cable.
Uber Londono
Hello,
Customer I asked configure in my trunk ports in SW1 and SW2:
storm-control broadcast level 20.00
no cdp enable
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
These commands are for Cisco IOS, the question is, wich are the equivalence in Extreme EXOS.
Thanks
Uber Londono
The Problem was solved with stacking cable and LAG betwen SW1 and SW2, working in redundancy mode "Maximal".
Thanks all for your help.
