LOST FRAME SIZE 64 - 350
  • Problem
  • Updated 1 year ago
  • Not a Problem
I have a domain eaps , and i did a test for a frame size 64 bytes , for the primary port the test is sucefull but when did a fail over at  the secondary port  test no pass.
I have configure jumbo frame , can you share the possibilities for this scenery ?
Photo of E FIERROS
E FIERROS
  • 110 Points 100 badge 2x thumb
  • frustrated
Posted 1 year ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,484 Points 10k badge 2x thumb
Hello E Fierros,
Can you please elaborate on the test and the process you went through to fail over EAPS?
Photo of E FIERROS
E FIERROS
Yes ,  i have the fallowing configuration
* a1-jade-ps-mx.1 # show eaps "eaps-perisur"
  Name: eaps-perisur                            Priority: Normal
  State: Complete                               Running: Yes
  Enabled: Yes    Mode: Master
  Primary port:   28            Port status: Up Tag status: Tagged
  Secondary port: 26            Port status: Blocked    Tag status: Tagged
  Hello Egress Port: Primary
  Hello timer interval: 10 sec  0  millisec
  Fail timer interval:  30 sec  0  millisec
26     d1-ppps-ps-mx             00:00:00:04:96:35:d3:99   1:48   19     14
28     d2-ppps-ps-mx             00:00:00:04:96:35:d3:4c   1:47   14     14
* a1-jade-ps-mx.3 #
* d1-ppps-ps-mx.1 # show  eaps "eaps-perisur"
  State: Links-Up                               Running: Yes
  Enabled: Yes    Mode: Transit
  Primary port:   49            Port status: Up Tag status: Tagged
  Secondary port: 48            Port status: Up Tag status: Tagged
  Preforwarding Timer interval: 15 sec
  Last update: From Master Id 00:04:96:97:dd:c6, at Thu Jun 15 15:24:14 2017
48     a1-jade-ps-mx             00:00:00:04:96:97:dd:c6   1:26   56     14
49     d2-ppps-ps-mx             00:00:00:04:96:35:d3:4c   1:49   8      218
d2-ppps-ps-mx.1 # show  eaps "eaps-perisur"
  Primary port:   47            Port status: Up Tag status: Tagged
  Secondary port: 49            Port status: Up Tag status: Tagged
The situation is when change the path for the secondary port (fail over) the test that ran fail. Exactly with frames 64 bytes - 350 bytes
I saw a congestion over the neighbors port but for the route primary (a1-jade - d2-ppps-d1-ppps) is the same behavior and the test dont have errors (frames loss)
Photo of E FIERROS
E FIERROS
This is the capture of errors
Photo of EtherMAN
EtherMAN, Embassador
  • 6,456 Points 5k badge 2x thumb
Did the redundant path take over and your test stopped dropping frames?  There is always some packet loss when you have a link failure and there will be some packet loss when you restore.  I am assuming that this is what you are seeing is a pass or fail from a test set based purly on packet loss and not how long it takes the network to restore when you do the fail over.
Photo of E FIERROS
E FIERROS
Hi Ethernet Man , Thanks for the information  and know maybe exist the posibility  drop paquets when did a fail over. But the situation is that I make or ran a test RFC2544 because I am checking the 2 path ( primary and secondary) like attached topology nothing change on the path only when did a change over the eaps- ́perisur.  For one side the test is exitoso (primary) but for the second path is not working fine and appears lost frames
Photo of EtherMAN
So with a 3 point ring where are you placing your test set and where is the loopback for your testing ?   This would help you narrow down a problem with one of the links.
Photo of E FIERROS
E FIERROS
Ok the equipment that function like a loopback is connected on port 1 equipment a1-jade and the emisor equipment is connected in another ring .
