LX SFP not working in shared port
  • Problem
  • Updated 2 years ago
  • Solved
Just purchased a new X440 - G2 switch and Extreme 1GB LX SFPs.  I am not able to get the SFPs to work in the shared ports (using port 47/48).   Is there something I need to do activate those ports to work with the SFPs?  I've tried different Single Mode patch cables as well as different ports/switches on the other end.  I know those have worked in the past.   Ideas?  ALso, can I plug these SFPs into the 10GB ports on the back of the switch?
Photo of Chris Youngblut
Chris Youngblut
  • 110 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Hmm.. What if you do a show port transceiver information detail, what do you get for 47/48?
This command might work
configure ports 47 preferred-medium fiber force
Chris Youngblut
I get the following when I show port transceiver info:
47        31.59    -4.89    -inf*      8.30          3.29          N/A
I ran the second command and still nothing.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,486 Points 10k badge 2x thumb
It looks like the RX power on that port is -infinity dBm, so nothing is being received. Have you tried swapping the fiber pairs on one end of the link? I suspect both optics may be transmitting onto the same fiber strand.
Photo of Jeremy
Jeremy, Embassador
I second that.  Just saw the reply... but your transceiver is working, because you can see the transceiver statistics.  As Brandon pointed out, the receive port is not actually receiving any light.  Swap them fibers and give it a try!
Photo of Chacko
Chacko
  • 1,206 Points 1k badge 2x thumb
Hi Chris,
we had a similar problem with a x670-G2 after upgrading to 21.1.3.7.
We had to configure the speed settings manually (in our case 1G/Full).
Before updating, the auto-negotiation worked fine.
So you can try to hard-configure the speed settings.
Best Regards
Chacko
Photo of Jeremy
Jeremy, Embassador
Also, what is the transceiver you were using on the other side? The wavelength will need to be the same, for example both transceivers would need to be 850 nm
Chris Youngblut
Thanks for everyone's comments.  I found out that the Extreme SFP I was using was not compatible with the Cisco switch.  I thought I had checked that earlier but was mistaken.  Once I installed an SFP that was Cisco compatible, it worked fine.  I appreciate all the troubleshooting tips - they will come in handy in the future I am sure!
