M-LAG between 4 agregation switches
  • Question
  • Updated 5 years ago
Create Date: Oct 5 2013 4:26PM
Hello,
I have a campus network composed of many access switches (X460) in buildings, on two sides of a street.
I would like to set up an agregation layer composed of four X670 switches (two on each side of the street), so that i can have redundant connections between each access switch and its two agregation switches). I also need to propagate vlans between these agregation switches.
I plan to use M-LAG :
  • between each access switch and its two agregation switches (no problem, standard design)
  • between the four agregation switches, in full-mesh flavour => here i have a doubt.
I have searched for design guidelines in the XOS concepts guide, in this forum and other websites but never found a clear answer to the question : how many M-LAGs do i have to create on the agregation switches for the full-mesh connection of these four switches ?
As stated in the drawing below, i gues that i would have to create four regular LAGs and also four M-LAGs (for each regular LAG on a X670, i have to declare the corresponding M-LAG on the two X670 on the other side) :
So I gues i would declare this configuration (just talking about X670 full-mesh connection, here i don't consider the LAG for the ISC link and the M-LAGs for the access switches):
X670 #1 : LAG 1 and M-LAG 3 and 4
X670 #2 : LAG 2 and M-LAG 3 and 4
X670 #3 : LAG 3 and M-LAG 1 and 2
X670 #4 : LAG 4 and M-LAG 1 and 2
Am i correct ?
If someone already tested this design or have suggestions about it, i'm very interested.
Best regards,
Gabriel
(from Gabrielboubil)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Oct 7 2013 1:48PM
IMO, you only need one MLAG in each switch, which will contain one lag from each. It's not even possible to create a M-LAG with the second port of a LAG, because there is no way to refer to this second port. When you create a lag only the master port is used for reference.
(from Luis_Coelho)
Create Date: Oct 8 2013 8:55AM
Thanks for the answer.
You're right, i won't be able to access the individual ports if they are already in a LAG.
So on each X670, i can declare one M-LAG and put the primary port of my LAG inside the M-LAG.
Globally i will have one M-LAG on each side.
Thanks for your help,
Gabriel
Create Date: Oct 11 2013 4:43PM
What program did you use to make that diagram?
Thanks,
(from Jeremy_Homan)
Create Date: Oct 12 2013 1:32PM
I used Microsoft Visio, and saved the diagram as a PNG file for uploading.
Gabriel
