MAC Authentication issue with HP5500 Series and Extreme NAC
  • Problem
  • Updated 3 years ago
  • Solved
  • (Edited)
Hello,
haven’t found any thread with NAC and HP Procurve model A5120 or any 5500-Serie Model.
Procurve is really limited in terms of configuration possibilities. Nevertheless,  I’m running into the issue that the  switch is not authenticating the connected supplicants.
Once a Host/PC is connected, I can’t observe any Auth-request  reaching the NAC Gateway. NAC Gateway it not getting any MAC-Auth requests.
1)      Switch can reach the NAC Gateway
2)      Switch is declared as Radius Client in  NAC and is as well configured with the corresponding  Radius-Server and shared-Secret
3)      Switch is monitored by the  Netsight Console with respective SNM-Parameter
Has anybody successfully couple this HP-Model series with Extreme NAC?
Any configuration example? I’ve actually configured with the HP-configurationguide.
Thanks in advance for any hints.
Regards
Gradelain
Photo of Gradelain Ngouni
Gradelain Ngouni
  • 480 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Michael Kirchner
Michael Kirchner
  • 1,846 Points 1k badge 2x thumb
Hi Gradelain,
I have successfully implemented Port Authentication with HP Procurve. Be aware of the firmware running on the switch. HP had several problems with authentication so you may wanna try a current release.
radius-server host X.X.X.X key "MySharedSecret"
radius-server host Y.Y.Y.Y key "MySharedSecret"
radius-server retransmit 1
radius-server dead-time 5
aaa accounting network start-stop radius
aaa authentication port-access eap-radius
aaa port-access authenticator 1
aaa port-access authenticator 1 server-timeout 30
aaa port-access authenticator 1 reauth-period 36000
aaa port-access authenticator 1 client-limit 3
aaa port-access authenticator active
aaa port-access mac-based 1
aaa port-access mac-based 1 addr-limit 3
aaa port-access mac-based 1 reauth-period 36000
aaa port-access mac-based 1 unauth-vid 1
aaa port-access 1 controlled-direction in
What's your config like?
Regards
Michael
(Edited)
Gradelain Ngouni
Hello Michael,
thanks a lot for your Feedback.
i think i should perhaps first of all try with a FW upgrade. i'm running version 5.20 Release 2221P02
Switch-Model: H3C S5120-24P-EI
none of the "aaa" configuration above is being accepted.
only following confguration were possible based on the configuration guide:
#Global:
dot1x
 dot1x authentication-method eap
#Radius
radius scheme nac
 primary authentication 192.168.10.114
 primary accounting 192.168.10.114
 key authentication cipher $c$3$3MWqYRjTqeraZV2AQVBhlp0ytjtH8VCuu0j6Ow==
 key accounting cipher $c$3$KhAkPm6nBU1alb/PtACj0YOsc9ynQ4czya6moA==
 user-name-format keep-original
domain nac
 authentication login radius-scheme nac
 authorization login radius-scheme nac
#Test interface:
interface GigabitEthernet1/0/2
 mac-authentication
 dot1x re-authenticate
regards
Gradelain
