MAC move seen in Cisco switch connected to Extreme
  • Question
  • Updated 3 years ago
  • Doesn't Need an Answer
Okey but I have other question and I have Cisco 3650 L3 end two xos summits 430 24t connecting trunk connection. Cisco L3 say flopping extreme switch connecting ports to vlan 1. What recommend give me about that.
Note: This conversation was created from a reply on: X430-24p and summitlite-16.1.2.14.xos firmware problem.
Photo of Merab Katibashvili
Merab Katibashvili
  • 112 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,304 Points 10k badge 2x thumb
Hi Merab,
I am assuming this Cisco switch is reporting MAC moves. What is the MAC address that it is showing?
I have seen this in the past due to EDP or ELRP packets being seen from both switches.
-Brandon
Photo of Drew C.
Drew C., Community Manager
  • 39,442 Points 20k badge 2x thumb
Hi Merab,
Do you still need assistance with this issue?
Photo of Terry Harcleroad
Terry Harcleroad
  • 96 Points 75 badge 2x thumb
We have a CISCO 6509 reporting flapping on ports that are using Extreme switches at other end.
Mac address - 00e0.2b00.0001
What can be done to rectify this and eliminate the error clogging up our logs?
  • 13,280 Points 10k badge 2x thumb
This is due to either EDP packets or ELRP packets, both of which are sourced from this MAC address.
I would suggest disabling EDP on the ports that connect to non-EXOS switches. If this is due to ELRP and you do not want to disable it on those ports, you may want to see if it is possible to exclude a specific log message from the Cisco's log buffer.
(Edited)
Photo of Drew C.
  • 39,134 Points 20k badge 2x thumb
Agreed.  You can disable EDP on the ports connecting to the Cisco with the disable edp ports command.
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
Hi Terry, this MAC address is used by EDP (Extreme Discovery Protocol).
Since your are connecting those ports to a Cisco device, you can disable EDP on specific ports with disable edp ports <port_list> command.
You can also check the GTAC Knowledge link below for details:
https://gtacknowledge.extremenetworks.com/articles/Q_A/Why-are-my-non-Extreme-devices-reporting-link...
Terry Harcleroad
Many thanks!   Much appreciated
