mac to role for VoIP Phones and TVCC
  • 2
  • Question
  • Updated 5 months ago
  • Answered
Good Evening, I am going to configure a new EMC to manage different Switch EOS and XOS.
Because I am new with this Software I want to know if is there a possibility to create a MAC to ROLE to check and put on a correct Vlan Phones and TVCC from the OUI. Is necessary insert a password for every phones/TVCC or not ? Thanks in advance Giuseppe
Photo of Giuseppe Montanarella
Posted 5 months ago
  • 2
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 5,192 Points 5k badge 2x thumb
Hello,
MAC to Role mapping mapping support is based on platform. Please check the following firmware support documentation to identify if your platform supports MAC to Role Mapping.
https://documentation.extremenetworks.com/release_notes/netsight/9035428_FirmwareSupport.pdf
You can configure a Mapping with mask for an OUI match. There is no tool tip in Extreme Management Center, but the format is 11:22:33:00:00:00/24. If any digits are outside of the masked range they will be turned into 0s.
This is also something that Extreme Control is very good at, and can apply policy based on MAC or MAC oui in a manageable group, with MAC to Role mappings if you have large amounts of MACs, or OUIs each one will take up a rule slot.
I'm not sure what you mean by "Is it necessary to insert a password for every phone". Could you elaborate?
Thanks
-Ryan
Good Morning, first of all thanks for your reply.
Reading around the web I found that to work with mac authentication ( or mac to role ) it was necessary create a connection to a Radius Server and put one password for every mac. I am doing some test because the target is ceate a rule to apply to all phones and to all TVCC. The next step will be UPM using EMC. Thanks and Have a nice day, Bye Giuseppe
If using an Extreme Control appliance then there is no need to create a password for every MAC. Extreme Control will successfully authenticate any MAC authentication and password without configuration. Extreme Control uses MAC authentication for visibility and policy assignment.
Thanks
-Ryan
