Management capacity of WiNG Virtual controller
  • Question
  • Updated 7 months ago
  • Answered
Hi community,
Could someone let me know the management capacity of a WiNG AP (virtual controller) such as max concurrent clients, user entry, WLAN,...like a real controller.
Thanks so much.
Photo of Son Nguyen
Son Nguyen
  • 1,298 Points 1k badge 2x thumb
Posted 7 months ago
Photo of Timo
Timo
  • 3,210 Points 3k badge 2x thumb
You can find most information in the data sheet.
The limit is maybe not at the controller, but at the RF Domain.
For example a AP can just "control" 128 per RF Domain. With the AP84xx, AP85xx and AP7632 the limit is extend to 256 APs.
To you would build one big network or manage several locations?
Photo of Son Nguyen
Son Nguyen
Thank you Timo, but I want to know some information not shown in the datasheet such as limited concurrent clients per site, limited user entry, WLAN, user database with Virtual controller?
Photo of Timo
Timo
You can get this information from your local Extreme Networks SE.
I'm sure, that there are some documentation where you can get this information. But you need to point your needed information.
Client count for example is 128 or 256 per radio. I think it depend on you AP type. Also that's a number you hopefully would never see on a AP, because it's mostly not possible.
Photo of Son Nguyen
Son Nguyen
Thanks Timo, the important information I need to know is the limitation of Captive portal database of entire wifi system when using Virtual controller mode with internal Radius server?
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,218 Points 4k badge 2x thumb
Hi Son;
 Here is the datasheet for the ExtremeWirelessTM WiNG VX 9000 Controller
Photo of Son Nguyen
Son Nguyen
Thanks Robert, but I want the information of the Virtual controller by using an AP?
Photo of Aviv Kedem
Aviv Kedem
  • 1,522 Points 1k badge 2x thumb
Hello Son Nguyen,
From my own experience, for example AP7502 you can create 2 simultaneous SSH sessions but when creating the 3 or 4 connection is prohibited with out of RAM message. When with AP6532 or the newest AP models don't had that problems. So only limitation is RAM.
If you searching for a management configuration limitation of device, I can give you a direction to see in to the config file in the internal memory of your device. Update me if you want to know the file path.
Regards,
Aviv
Photo of Aviv Kedem
Aviv Kedem
Hello,
Check here with CLI for limitations:
more system:/proc/dataplane/limits
Otherwise your limit is the RAM memory.
Regards,
Aviv
Photo of Son Nguyen
Son Nguyen
Thank you so much Aviv. Can I get the limitation of Captive portal database of  entire wifi system when using Virtual controller mode with internal Radius server?
Photo of Aviv Kedem
Aviv Kedem
Hello Son,
I don't sure for 100% but maybe this limitation is the file descriptors, you can check with CLI:
AP-lab>service show sysinfo
System Information:
Free RAM:  24.5% (13280 of 54024)  Min: 10.0%
File Descriptors: free: 7676 used: 516 max: 25500
CPU load averages: 1 min: 5.1%  5 min: 4.6%  15 min: 4.7%
Kernel Buffers:
Size:      32    64   128   256   512    1k    2k    4k    8k   16k   32k   64k  128k
Usage:      0     0     0     0     0     0     0     0     0     0     0     0     0
Limit:  32768 10240  4096  4096  8192  8192 16384 16384  1024   512   256    64    64
AP-lab>
Regards,
Aviv
Photo of Timo
Timo
AP6521 have a limit of 128 local radius user. All other APs limited by 256 user in the database.
This user can be EAP-MSCHAPv2 or Captive Portal user.
If you use local radius with LDAP as database, there is no limit. Also for PEAP-TLS or TLS there is "no limit", because in both cases the database is not local. Same, if you use central VX or NX. The limit is for the user database mapped on an AP.
Photo of Son Nguyen
Son Nguyen
Thank you Timo, very clear information.
