Management Center EXOS Requirements
  • Question
  • Updated 8 months ago
  • Answered
Are there any limitations on EXOS versions for Summit switches that are required for a device to be managed by Management Centre? For example, if devices are currently being managed by Netsight and we were to upgrade to Management Centre, would there be any requirement to upgrade any EXOS versions first?
Photo of Paul
  • 342 Points 250 badge 2x thumb
Posted 8 months ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,582 Points 5k badge 2x thumb
It depends on what functionality your looking for, and the products/versions you're adding.  Netsight (Extreme Management) will be able to discover almost all devices, and can back them up with a few tweaks to the scripts.
You can get a trial, and test it out in a VM before you move over.  I would do that first.
Photo of Bin
Bin, Employee
  • 5,128 Points 5k badge 2x thumb
Hello Paul,
Agree with Stephen. It is better to test at first for EXOS feature which you are looking for.
On the other site, there is one article for considerations to upgrade Management Center 8.x.
Best regards,
