Massive Syslog Messages for RADIUS Accounting
  • Question
  • Updated 2 years ago
  • Doesn't Need an Answer
Hi there,
we discovered some Switches are sending  "RADIUS Accounting Errors" to our NetSight. They are look pretty much like this:
AAA[13]RADIUS Attempted the configured number of retries (3) to accounting server #2 without a server response for 00-XX-XX-XX-XX-XX (username '00-XX-XX-XX-XX-XX') on port tg.13.3
The most messages are from our bonded S8-Chassis, which obviously got the most users connected.
The Server "number" varies as well as the ports, but all of our 5 NAC Gateways are up and running... and we don't see other errors on the network.
The switch sends about 20-30 Messages every few minutes.
Does anyone know what this Messages could cause or exactly mean?
Thanks in advance,
Martin
This is our RADIUS Config:
# radius
set radius enable
set radius timeout 10
set radius server 1 10.233.23.21 1812 :secret:
set radius max-sessions 6000 1
set radius server 2 10.233.23.22 1812 :secret:
set radius max-sessions 4500 2
set radius server 3 10.233.23.23 1812 :secret:
set radius max-sessions 4500 3
set radius server 4 10.233.23.24 1812 :secret:
set radius max-sessions 6000 4
set radius algorithm round-robin
set radius accounting enable
set radius accounting server 1 10.233.23.21 1813 :secret:
set radius accounting retries 3 1
set radius accounting timeout 10 1
set radius accounting server 2 10.233.23.22 1813 :secret:
set radius accounting retries 3 2
set radius accounting timeout 10 2
set radius accounting server 3 10.233.23.23 1813 :secret:
set radius accounting retries 3 3
set radius accounting timeout 10 3
set radius accounting server 4 10.233.23.24 1813 :secret:
set radius accounting retries 3 4
set radius accounting timeout 10 4
Photo of MartinS
MartinS
  • 430 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
I'm not an expert on RADIUS accounting but could you check whether it's it enabled on the NACs ?
