Max number of GRE tunnels
  • Question
  • Updated 3 years ago
  • Answered
is there a limit in the number of GRE tunnels that can be configured in a S-Series switch?
Photo of Esteban Fernandez
Esteban Fernandez
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Piotr Owczarek
Piotr Owczarek
  • 514 Points 500 badge 2x thumb
Itis limited as Tunnel interfaces:
For Example in SSA or S3:
  tunnel-interfaces                     62         1
You can check limits with "show limits" command on S/K Series Switches.
Photo of Straw, Glyn
Straw, Glyn, Employee
  • 2,152 Points 2k badge 2x thumb
Tunneling Capacities
Total Number of Tunnels (S155)                         62
Total Number of Tunnels (S150/S130)                62 *Licensed
Total Number of Tunnels (SSA150(A)/SSA130)  62 *Licensed
Some of these limits may not be enforced by the firmware and may cause unknown results if exceeded.
License Features
The S-EOS-S130 license adds VRF, BGP and tunneling features to the S130 class of HW.
A single license will be required per chassis or SSA. The license is applicable to: S130 class SSA, S3 chassis (using S130 I/O modules), The S1, S4, S6 and S8 chassis using the S130 Class fabrics or a combination of S150 and S130 Class fabrics (The VRF functionality in the S150 class is included without the need for a license.)
The S-EOS-S150 license adds GRE tunnel support to the S150 Class of HW. This license will be extended in the future to add additional tunneling options. The S155 class supports these features without the need for the license.
Esteban Fernandez
Thanks!
Are the numbers the same for S180 modules?
Hi Esteban,
The numbers are the same for the S180/S140 as for the S155. i.e. 62 with no license requirement.
I will update the knowledge document to add those products as well.
Best Regards
Glyn
