Max speed of new WiNG APs 7622 and 7602
Son_Nguyen2
New Contributor III
Hi Community,
Two new APs 7622 and 7602 are have new operation modes as
concurrent single stream (1x1:2.4G + 1x1:5G), dual stream (2x2:2.4G or 2x2:5G), but i don't see the max speed each AP can reach in their datasheet.
So how is the actual max speed of them in two operation modes?
9 REPLIES 9
RobertZ
Captured this knowledge article based on the above conversation.
Max speed of WiNG APs 7622 and 7602
Blake_Williams1
Max speed is listed at up to 867Mbps with 2 streams enabled on the 5Gzh band or 300Mbps with 2 streams enabled on the 2.4Ghz band. Half that per band in 1x1 mode on each radio.
thank you
