Maximo de rutas estaticas en switch X460-G2
  • Question
  • Updated 4 weeks ago
  • Answered
Greetings, I would like to know which is the maximum static routes that an X460-G2 switch supports and if it depends on the EXOS image that the equipment has?
Photo of Enmanuel Alexander Lopez Ramirez
Posted 4 weeks ago
Photo of Tomasz
Tomasz
  • 2,382 Points 2k badge 2x thumb
Please take a look here at 'IPv4 LPM entries':
https://cloud.kapostcontent.net/pub/dd5f1abb-be45-4e23-a5f8-76147a01e1e3/x460-g2-data-sheet-1.pdf
Some values (not necessarily the routing table limit) might change over time and not every detail is in the datasheet (some limits might depend on other factors). Actual limits you can find in release notes per each firmware version you currently manage. Example for EXOS 22.5:
https://documentation.extremenetworks.com/release_notes/ExtremeXOS/22.5/ExtremeXOS_22.5_RelNotes.pdf
Here is the generic container for release notes and other nice docs for EXOS:
https://www.extremenetworks.com/support/documentation/extremexos-22-6/
Hope that helps,
Tomasz
(Edited)
