Maximum number of ACL in WM3700
  • Question
  • Updated 2 years ago
  • Answered
How many ACL ́s can I configure in a WM3700, and is there a maximum precedence in every ACL?
Photo of Jesús Aguilar
Jesús Aguilar
  • 108 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Chad Smith
Chad Smith, Alum
  • 5,640 Points 5k badge 2x thumb
Jesús,
The maximum precedence value is 5000.  You can find ACL and other scaling limitations in the following document:
atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/S_W5CAMPUSDEPLOY.pdf
According to that document there is a 512 rule max for IP ACLs and 128 rule max for MAC based ACLs.
Another way to get some limits is with the following command:
NOC_WM3700-2#more system:/proc/dataplane/limits
NUM_EXT_PORTS=4
NUM_ROUTER_PORTS=1
NUM_CONCENTRATED_PORTS=0
NUM_CONCENTRATOR_PORTS=0
NUM_LOCAL_PORTS=2
NUM_VMGMT_PORTS=0
MAX_MLTS=2
NUM_PORTS=9
NUM_MCAST_PORTS=9
NUM_GRE_TUNNELS=0
NUM_DYN_GRE_TUNNELS=0
NUM_TUNNELS=0
NUM_PPP_TUNNELS=2
NUM_INTERFACES=4099
MAX_SVIS=1024
MAX_MUS=8192
MAX_LOCAL_MUS=256
MAX_DATAPLANE_APS=256
MAX_WLANS=256
MAX_DATAPLANE_RADIOS=512
MAX_LOCAL_RADIOS=0
MAX_LOCAL_NON_SENSOR_RADIOS=0
MAX_BSS_PER_RADIO=16
MAX_WLAN_PER_RADIO=16
MAX_PROBE_ENTRIES=4096
MAX_RADIO_PROXIMITY_ENTRIES=64
NUM_THREADS=32
NUM_CTRL_THREADS=4
NUM_DATA_THREADS=28
NUM_PACKETS=32768
NUM_FW_FLOWS=206438
fw_num_flows=206438
FW_MAX_USER_CFG_ACL=500
FW_MAX_ACL=504
NUM_REVAL_CHECKS_PER_FLOW=17
NUM_REVALIDATION_CTRS=2048
NUM_IPSEC_TUNNEL_REVAL_CTRS=1024
NUM_FDB_ENTRIES=65536
MAX_MSTI=16
NUM_IGMP_SNOOP_PORTS=6
MAX_MINT_NEIGHBORS=1843
MAX_MINT_VLAN_NEIGHBORS=460
MAX_MINT_ROUTES=7372
TIMESTAMPS_PER_SEC=66666666
HZ=250
(Edited)
Jesús Aguilar
Thanks Chad
