MCX on AP7562 - Rate Selection Method
  • Question
  • Updated 11 months ago
  • Answered
Hi.
I'm configuring a new Mesh link with some AP7562s FW 5.8.6.5-002R
Configuration is performed from a RFS6000 controller and APs are running the AP7562-LEAN-5.8.6.5-002R.img image.
When it comes to doing the standard Mesh setup I cannot choose Opportunistic for the Rate Selection Method - get error "Rate Selection cannot be changed for device [ap7562]".
Any reason for this? I've never had this error when configuring other mesh APs.
Thanks
Gary
Photo of Gary Hartstone
Gary Hartstone
  • 316 Points 250 badge 2x thumb
Posted 11 months ago
Photo of Bartholomew Lai
Bartholomew Lai, Employee
  • 344 Points 250 badge 2x thumb
HI Gary, The opportunistic rate selections are only supported on the AP7161 and AP8163 as per the guide.
Opportunistic - Configures the opportunistic radio link adaptation (ORLA) rate selection mode The ORLA algorithm is designed to select data rates that provide best throughput. Instead of using local conditions to decide whether a data rate is acceptable or not, ORLA pro-actively probes other rates to determine if greater throughput is available. If these other rates do provide improved throughput, ORLA intelligently adjusts its selection tables to favour higher performance. ORLA provides improvements both on the client side of a mesh network as well as in the backhaul capabilities. Note: The ORLA rate selection mode is supported only on the AP7161 and AP8163 model access points.
please refer to the guide:
http://documentation.extremenetworks.com/WiNG/5.9.1/9035205_WiNG_5_9_1_WC_CLI.pdf
Gary Hartstone
Great explanation, thanks for the quick reply.
