Memory leak by process CFGMGR after save configuration
Кирилл_Кучеров
We have such problem. Always after saving configuration, we have found the memory leak, about 2MB from process CFGMGR. Because of this we forced to reboot the switch after some times.
System Type: X650-24x(SSns)
Secondary ver: 12.5.1.6
Image Selected: secondary
show configuration "cfgmgr" detail
# Module cfgmgr configuration.
disable cli-config-logging
configure cli max-sessions 8
configure cli max-failed-logins 3
disable cli scripting permanent
configure idletimeout 20
enable idletimeout
What can be done in this situation?
2 REPLIES 2
Кирилл_Кучеров
Thanks Konstantin.
Korsovsky__Kons
Hi Kirill,
EXOS 12.x was decommissioned long ago.
The best way to proceed would be to upgrade to the latest recommended release first:
Hardware/Software Compatibility and Recommendation Matrices
End of Sale and End of Support
Thanks,
Konstantin
