MGMT port connection
  • Question
  • Updated 5 years ago
Create Date: May 16 2012 9:02PM
Hi
I am from Sydney and configuring Black Dimond 8800 modular switch. I have configure vlan Mgmt with management ip address.
I am successfully able to connect my laptop to the mgmt port using ethernet cable.
But once I disconect my pc and reconnect with same cable, Management port stop responding and cant connect.
Once I reboot the switch it comes back and allow me to connect via mgmt port again.
Is this normal or any software bug?
Pls help
Regards
(from Bhaumik_Trivedi)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: May 17 2012 11:04AM
Verify if the fdb entry exists for the laptop on the switch after you disconnect it...
Was this a one-off incident or does it happen everytime?
it could be a bug as well...Verify with TAC...what version of code is it?
(from Arpit_Bhatt)
Create Date: May 17 2012 4:23PM
Hi
Thanks for response. Well it is happen everytime. I have not verified fdb entry.
I am now asking TAC. I guess thats the best option.
Thanks
