Migrating settings from cisco virtual controller V2110 to C5210
  • 2
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Hello  i have currently two V2110  controller in HA. And we have purchased 2 – C5210s and we be installing them soon. My question is how do I migrate them over the C5210? I do not believe that I cannot simply back up the V2110(Config’s, CDRs, Logs, Audit and Rogue) and restore that to the C5210. Anyone has tried before? .Thanks
Photo of Elena Madrigal
Elena Madrigal
  • 514 Points 500 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
There are different options and they depend on the setup, skill...
Let's say the current setup is hot standby HA = 2nd controller has no local APs.
Just turn of the 2nd controller, turn on the new C5210 and configure the HA IP and the major settings should get synced, if all is in sync. move the APs to the C5210, turn off the 1st controller and replace it with the 2nd C5210 and config HA IP and sync again and that is it.
Controllers old/new should have the same software installed.
You'd also change some settings in the config file - mainly the port numbering/naming and import the config file - but for that you need the right skill, if you never worked with the CLI commands just forget it.
-Ron
Photo of Careno, Ryan
Careno, Ryan, Employee
  • 1,092 Points 1k badge 2x thumb
The migration path from a V2110 to C5210 should support the configuration to be saved off the V2110 and loaded on the C5210.  Make sure they are on the same code track first.  Here's our maintenance guide going over the steps starting at the bottom of page 45:
http://documentation.extremenetworks.com/wireless/MG/downloads/Wireless_Maintenance_Guide.pdf
The guide shows how to export the config and import it via CLI on SSH session, but the same can be done through Web GUI export / import of configuration.
Regards,
Ryan Careno
Elena Madrigal
Migrated done successfully, thnks for support.
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
I know you've been a member for a while Elena, but really glad to see you making your voice heard on the Hub.  Good stuff!
