MLAG issue
  • Question
  • Updated 4 months ago
  • Answered
we want to createing MLAG between 2 switches X620. During MLAG creation does IP of all VLAN between 2 switches be same using or same subnet range using.
Suppose that 2 switches(X620) we have and we have 5 vlan and there vlan-IP applied on switch-1. Does IP of all vlan's of switch-1 would be same using on switch-2 or any same subnet range.
Switch-1(X620)
VLAN2=192.168.1.2
VLAN3=10.10.10.1
Switch-2(X620)
VLAN2=192.168.1.2
VLAN3=10.10.10.1
Photo of Alok Shukla
Alok Shukla
  • 834 Points 500 badge 2x thumb
Posted 5 months ago
Photo of Andrew Imam
Andrew Imam, Employee
  • 1,006 Points 1k badge 2x thumb
Hi Alok,
If you intend to configure/enable VRRP on each of the MLAG peers to provide Layer 3 Gateway Redundancy, then for each VLAN you can assign a unique IP address and configure another IP address to be used for VRRP (the same IP on both switches). For example:
Switch-1(X620)
VLAN2=192.168.1.2/24 /VRRP IP=192.168.1.254/24
VLAN3=10.10.10.2/24 /VRRP IP=10.10.10.254/24
Switch-2(X620)
VLAN2=192.168.1.3/24 /VRRP IP=192.168.1.254/24
VLAN3=10.10.10.3/24  /VRRP IP=10.10.10.254/24
As part of your network design, you would need to determine whether you want to setup VRRP with one switch as the VRRP master and the second switch as the VRRP Backup or you would like to have Active-Active VRRP.
Please let us know if you have any other questions.
Thank you.
Best regards,
Andrew
Alok Shukla
 For Creatting VRRP which is best for me VRRP active- active or active-standby?
Photo of Sushruth Sathyamurthy
Sushruth Sathyamurthy, Employee
  • 496 Points 250 badge 2x thumb
Active-active can be used. You will need to write an ACL to block the VRRP advertisements in order to achieve this. Andrew has attached a link to an article earlier in this thread.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,280 Points 10k badge 2x thumb
Starting with 16.1 (16.2?), you have Fabric Routing to do that active/active VRRP without the ACL trick.
Alok Shukla
How do we create root bridge for Switch-A to vlan-1 and root bridge for Switch-B to vlan-2 in MLAG?
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,742 Points 10k badge 2x thumb
You don't, MLAG uses all links at the same time. STP is not supported on MLAG ports on EXOS, see e.g. "Can I combine MLAG and STP?".
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,364 Points 2k badge 2x thumb
How are you going to define connection to switch-1 and switch-2 within a single vlan, having same ip?
Alok Shukla
Hi Alok,
with MLAG you do not define a root bridge. You define a root bridge for STP, but EXOS does not allow the use of STP on an MLAG port.
Thanks,
Erik
