MLAG with 2 X650 to 1 Juniper MX5
  • Question
  • Updated 5 years ago
  • Answered
Create Date: Sep 12 2012 11:59PM
Has anyone had any experience with setting up MLAG between 2 Extreme X650 and 1 Juniper MX5.
So interface ge-1/0/8 and ge-1/0/9 on the MX5 connect into port 1 on X650 switch A (core1) and port 2 on X650 switch b (core2) using MLAG id 2.
The Juniper is sending LACP packets however not receiving any back from the X650s
 show mlag peer
Multi-switch Link Aggregation Peers:
MLAG Peer         : core2
VLAN              : isc-cbr         Virtual Router    : VR-Default
Local IP Address  : 172.30.110.1    Peer IP Address   : 172.30.110.2
MLAG ports        : 3               Tx-Interval       : 1000 ms
Checkpoint Status : Up              Peer Tx-Interval  : 1000 ms
Rx-Hellos         : 704374          Tx-Hellos         : 709225
Rx-Checkpoint Msgs: 5292            Tx-Checkpoint Msgs: 5298
Rx-Hello Errors   : 0               Tx-Hello Errors   : 0
Hello Timeouts    : 5               Checkpoint Errors : 0
Up Time           : 0d:20h:24m:46s  Peer Conn.Failures: 5
show mlag ports
                Local                                             Local   Remote
MLAG    Local   Link     Remote                           Peer    Fail    Fail
Id      Port    State    Link    Peer                     Status  Count   Count
2       1       A        Up      core2                    Up          0       0
1       5       A        Up      core2                    Up          0       0
(from shannon_rigby)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Sep 13 2012 12:10PM
Hello RigzThe current version of XOS does not support LACP with MLAG. That support will come in a version of code later in the year.P
(from Paul_Russo)
Create Date: Sep 13 2012 9:53PM
Thanks for your reply, turned of lacp on junipers all sweet.
Create Date: Sep 14 2012 11:59AM
Good to hear. LACP support is coming just not sure exact time. Should be before Feb 2013.
(from Paul_Russo)
Create Date: Sep 14 2012 2:51PM
yes that caught me out yesterday,
(from conrad_jones)
