MLT on Exos to work with Avaya MLT/SMLT
  • Question
  • Updated 1 week ago
  • Answered
Hello All,
How do I setup LACP/LAG on EXOS G450G2 to work with SMLT on Avaya VSP/Switches?
I know LACP, but I thought that MLT/SMLT is a specific type of LACP. I have two VSPs with SMLT to an EXOS X450G2 switch, how do I create an MLT on the EXOS switch with two ports?
is it simply:
enable sharing 1:47 grouping 1:47-1:48 ???
What should the algorithm and distribution-mode be?
Thanks,
Photo of Chad
Chad
  • 130 Points 100 badge 2x thumb
Posted 2 weeks ago
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,562 Points 10k badge 2x thumb
you are correct. If LACP is not needed, your command is good. If you need LACP, just add that keyword at the end. That way, it will default to L2 address for hashing. You can specific any other method (L3, L3_L4). It doesn't really matter for SMLT by itself, but to have a better traffic load-balancing from that switch, pick what you need.
Photo of Sushruth Sathyamurthy
Sushruth Sathyamurthy, Employee
  • 750 Points 500 badge 2x thumb
Yes, you are correct. As far as the EXOS switch is concerned, it is simply LAG/LACP
https://gtacknowledge.extremenetworks.com/articles/How_To/how-to-configure-sharing-LAG-LACP-in-Summi...
You can check out the article for information on algorithms and their working.
Photo of Chad
Chad
Thank you for the replies.
Ok, I will try it then. I would hope that in the future there would be an article, to give what is Extreme's recommendation on the best way to setup sharing on the EXOS when connected to MLT/SMLT switches. It sounds like LACT parameter is not needed, and any specific method (L2, L3... etc) should work anyways.
Thank you,
