mobility tunnel
  • Question
  • Updated 2 years ago
  • Answered
I have two controllers WC-35 with version 10.31.01.0048, and C4110 with version 09.21.10.0005, and i would like configure mobility tunnel between tow controllers, the controller ́s dont have HA, this is possible?
Photo of Salvador Gallo
Salvador Gallo
  • 452 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,186 Points 50k badge 2x thumb
Yes
Salvador Gallo
But is necessary create a HA?
Photo of SH
SH
  • 5,318 Points 5k badge 2x thumb
Hello Salvador,
you don't  need HA!
Regards
Stephan
Salvador Gallo
i tryed and the tunnel does not up, i have differents segment of network on interface of register 10.10.1.0/24 and 10.10.3.0/24. is necesary that the inferfaces have the same network segment?
  • 51,164 Points 50k badge 2x thumb
No, they don't need to be on the same VLAN/subnet.
Is a route configured on the controller so they could reach each other - you could try a ping from controller#1 to controller#2 to see whether routing works.
Photo of SH
SH
Mybe there is a firewall between your networks?
Visit the release notes for the necessary ports.
Salvador Gallo
The two controllers are in the same LAN conect at the core
Photo of SH
SH
Are you using NTP and do you have the same time on both controllers?
What do you see in the Reports->Mobility->Mobility Tunnel Matrix?
What do you see in the Logs for Mobility?
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,300 Points 2k badge 2x thumb
I assume but if not..add the mobility agents statically in the list?
Salvador Gallo
i cal see this logs:
manager: Mobility tunnel establishment failed with Peer 10.15.2.254. Please verify peer's reachability
agent: Mobility tunnels with Peers reset due to membership credentials change on current controller
I'm sorry but it's hard to help if you don't provide exact information.....
1) what is the IP of controller#1&2 interface that you'd like to use for mobility and how are the interface topologies are configured = physical or bridge@EWC
2) could you ping the IP this IP from controller#1 and vice-versa
Salvador Gallo
this is the information of controllers:
controller 1: interface physical 10.10.2.254/ 24 with Ap registrering, version 09.21.10.0005
controller 2: interface physical 10.10.3.254/ 24 with  Ap registrering, version 10.31.01.0048
and ping is successfull in both directions.
but controller 1 have 61 VNS configured and other controller have 3 VNS.
That IPs don't match with the IPs in the error message that you've provided...
"manager: Mobility tunnel establishment failed with Peer 10.15.2.254."
(Edited)
Salvador Gallo
sorry, the Second octet is 15 for both segment of network, 10.15.2.254/24 and 10.15.3.254/24
