Module in Slot-2 is removed, X460 stacks keep failing.
  • Problem
  • Updated 3 years ago
  • Solved
Hi There,
We have a bunch of X460's that are stacked in pairs and have 2 x 10Gb interfaces to a X670.
We seem to be getting systematic failures of these stacks first reporting a module being removed, but one has not physically being removed?
De-stacking the switchs seems to stop the problem. When the problem occurs the switch goes offline for a while, recovers and then the stack seems to have swapped roles and the other switch is now the master.
The error messages are below. Going to take a capture tomorrow to see if this is an issue having stacking than stacking itself.
The network origanlly had the switchs as two separate switchs using spanning tree but has since change the topology to use staking - so wondering if this and the equipment attached is causing the switchs problems
03/09/2015 06:37:08.28 <Info:AAA.LogSsh> Slot-1: Msg from Backup : 1375 of 1375bytes written to SSH System Config
03/09/2015 06:36:52.57 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:30 to aggregator
03/09/2015 06:36:52.57 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:29 to aggregator
03/09/2015 06:36:51.19 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:53 to aggregator
03/09/2015 06:36:50.91 <Info:HAL.Sys.Info> Slot-1: Input voltage to  in slot 2 is on. Output enabled.
03/09/2015 06:36:50.91 <Info:HAL.Sys.Info> Slot-1:  in slot 2 is present.
03/09/2015 06:36:45.23 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:8 to aggregator
03/09/2015 06:36:45.23 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:7 to aggregator
03/09/2015 06:36:45.23 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:6 to aggregator
03/09/2015 06:36:45.23 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:5 to aggregator
03/09/2015 06:36:32.15 <Info:AAA.LogSsh> Slot-1: Msg from Backup : Loaded Private Key of size 1375 from System
03/09/2015 06:36:22.43 <Info:vlan.dbg.info> Slot-1: Media SF+_SR is inserted into Port 2:53
03/09/2015 06:36:21.52 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is operational
03/09/2015 06:36:03.74 <Warn:cm.configNotInSync> Slot-1: Backup node has different configuration files than primary node. Auto configuration file synchronization will be performed.
03/09/2015 06:35:26.05 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is inserted
03/09/2015 06:35:25.11 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 06:35:25.10 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link up at 10Gbps.
03/09/2015 06:35:17.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 06:35:17.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link down.
03/09/2015 06:35:16.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 06:35:16.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link up at 10Gbps.
03/09/2015 06:35:13.81 <Info:HAL.Port.Info> Slot-1: Stacking port 1:1 link up at 10Gbps.
03/09/2015 06:35:12.96 <Info:HAL.Port.Info> Slot-1: Stacking port 1:2 link up at 10Gbps.
03/09/2015 06:32:38.06 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 06:32:38.06 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 06:32:37.94 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 06:32:37.94 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link down.
03/09/2015 06:32:37.88 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 06:32:37.88 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 06:32:37.88 <Info:HAL.Port.Info> Slot-1: Stacking port 1:1 link down.
03/09/2015 06:32:35.24 <Info:HAL.Port.Info> Slot-1: Stacking port 1:2 link down.
03/09/2015 06:32:34.18 <Warn:DM.Warning> Slot-1: Slot-2 FAILED (1) Dual Master
03/09/2015 06:32:34.17 <Crit:NM.NodeStateFail> Slot-1: Slot-2 has failed for the reason of "Dual Master".
03/09/2015 06:32:33.09 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is inserted
03/09/2015 06:32:32.55 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 06:32:32.55 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link up at 10Gbps.
03/09/2015 06:32:28.84 <Info:HAL.Port.Info> Slot-1: Stacking port 1:2 link up at 10Gbps.
03/09/2015 06:32:28.84 <Info:HAL.Port.Info> Slot-1: Stacking port 1:1 link up at 10Gbps.
03/09/2015 06:32:17.41 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:53 from aggregator
03/09/2015 06:32:17.40 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:30 from aggregator
03/09/2015 06:32:17.40 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:29 from aggregator
03/09/2015 06:32:17.16 <Info:vlan.dbg.info> Slot-1: Port 2:53 is Down, remove from aggregator 1:53
03/09/2015 06:32:17.12 <Info:vlan.dbg.info> Slot-1: Port 2:30 is Down, remove from aggregator 2:29
03/09/2015 06:32:17.12 <Info:vlan.dbg.info> Slot-1: Port 2:29 is Down, remove from aggregator 2:29
03/09/2015 06:32:17.08 <Info:HAL.Sys.Info> Slot-1: EDPS-300AB A-S6 in slot 2 is disconnected.
03/09/2015 06:32:16.97 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:8 from aggregator
03/09/2015 06:32:16.97 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:7 from aggregator
03/09/2015 06:32:16.97 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:6 from aggregator
03/09/2015 06:32:16.97 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:5 from aggregator
03/09/2015 06:32:16.95 <Info:vlan.dbg.info> Slot-1: Port 2:8 is Down, remove from aggregator 2:5
03/09/2015 06:32:16.95 <Info:vlan.dbg.info> Slot-1: Port 2:7 is Down, remove from aggregator 2:5
03/09/2015 06:32:16.95 <Info:vlan.dbg.info> Slot-1: Port 2:6 is Down, remove from aggregator 2:5
03/09/2015 06:32:16.95 <Info:vlan.dbg.info> Slot-1: Port 2:5 is Down, remove from aggregator 2:5
03/09/2015 06:32:16.93 <Warn:DM.Warning> Slot-1: BACKUP NODE (Slot-2) DOWN
03/09/2015 06:32:16.90 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 06:32:16.90 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 06:32:16.90 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 06:32:16.90 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link down.
03/09/2015 06:32:16.46 <Warn:DM.Warning> Slot-1: BACKUP is NOT in SYNC
03/09/2015 06:32:16.30 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 06:32:16.30 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 06:32:16.30 <Info:HAL.Port.Info> Slot-1: Stacking port 1:2 link down.
03/09/2015 06:32:16.30 <Info:HAL.Port.Info> Slot-1: Stacking port 1:1 link down.
03/09/2015 05:57:41.38 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:6 to aggregator
03/09/2015 05:57:39.67 <Info:AAA.LogSsh> Slot-1: Msg from Backup : 1375 of 1375 bytes written to SSH System Config
03/09/2015 05:57:23.56 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:30 to aggregator
03/09/2015 05:57:23.56 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:29 to aggregator
03/09/2015 05:57:21.73 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:53 to aggregator
03/09/2015 05:57:20.39 <Info:HAL.Sys.Info> Slot-1: Input voltage to  in slot 2 is on. Output enabled.
03/09/2015 05:57:20.39 <Info:HAL.Sys.Info> Slot-1:  in slot 2 is present.
03/09/2015 05:57:17.67 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:8 to aggregator
03/09/2015 05:57:17.67 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:7 to aggregator
03/09/2015 05:57:17.67 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:5 to aggregator
03/09/2015 05:57:03.26 <Info:AAA.LogSsh> Slot-1: Msg from Backup : Loaded Private Key of size 1375 from System
03/09/2015 05:56:55.56 <Info:vlan.dbg.info> Slot-1: Media SF+_SR is inserted into Port 2:53
03/09/2015 05:56:53.27 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is operational
03/09/2015 05:56:34.55 <Warn:cm.configNotInSync> Slot-1: Backup node has different configuration files than primary node. Auto configuration file synchronization will be performed.
03/09/2015 05:55:57.05 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is inserted
03/09/2015 05:55:56.94 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 05:55:56.94 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link up at 10Gbps.
03/09/2015 05:55:47.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 05:55:47.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link down.
03/09/2015 05:55:46.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 05:55:46.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link up at 10Gbps.
03/09/2015 05:55:43.69 <Info:HAL.Port.Info> Slot-1: Stacking port 1:1 link up at 10Gbps.
03/09/2015 05:55:42.84 <Info:HAL.Port.Info> Slot-1: Stacking port 1:2 link up at 10Gbps.
03/09/2015 05:53:04.26 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 05:53:04.26 <Info:HAL.Port.Info> Slot-1: Stacking port 1:2 link down.
03/09/2015 05:53:04.26 <Info:HAL.Port.Info> Slot-1: Stacking port 1:1 link down.
03/09/2015 05:53:04.26 <Erro:HAL.Stacking.Error> Slot-1: stackingConfigRequestHandler(00:04:96:6c:ec:f7): stmSendConfigReply() failed [-2].
03/09/2015 05:53:04.26 <Erro:STM.Library.Error> Slot-1: stmSendConfigReply(): write(8, 0x6e21e8, 76) = -1, failed [-2]
03/09/2015 05:53:04.26 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 05:53:03.98 <Warn:DM.Warning> Slot-1: Slot-2 unexpectedly RT_SYNCED from EMPTY
03/09/2015 05:53:03.97 <Warn:HAL.Card.Warning> Slot-1: Unexpected state transition for Slot-2 oldState EMPTY newState RT_SYNC_DONE
03/09/2015 05:53:03.84 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 05:53:03.84 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 05:53:03.82 <Warn:DM.Warning> Slot-1: BACKUP NODE (Slot-2) DOWN
03/09/2015 05:53:03.72 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 05:53:03.72 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link down.
03/09/2015 05:53:03.58 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 05:53:03.58 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 05:52:45.45 <Warn:cm.configNotInSync> Slot-1: Backup node has different configuration files than primary node. Auto configuration file synchronization will be performed.
03/09/2015 05:52:08.09 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is inserted
03/09/2015 05:52:07.68 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 05:52:07.68 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link up at 10Gbps.
03/09/2015 05:51:54.88 <Info:HAL.Port.Info> Slot-1: Stacking port 1:1 link up at 10Gbps.
03/09/2015 05:51:54.03 <Info:HAL.Port.Info> Slot-1: Stacking port 1:2 link up at 10Gbps.
03/09/2015 05:49:17.10 <Info:HAL.Sys.Info> Slot-1: EDPS-300AB A-S6 in slot 2 is disconnected.
03/09/2015 05:49:16.09 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 05:49:16.09 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 05:49:15.65 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 05:49:15.65 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link down.
03/09/2015 05:49:15.59 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 05:49:15.59 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 05:49:15.59 <Info:HAL.Port.Info> Slot-1: Stacking port 1:2 link down.
03/09/2015 05:49:15.59 <Info:HAL.Port.Info> Slot-1: Stacking port 1:1 link down.
03/09/2015 05:49:12.05 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is inserted
03/09/2015 05:49:11.81 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 05:49:11.81 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link up at 10Gbps.
03/09/2015 05:49:08.95 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:53 from aggregator
03/09/2015 05:49:08.95 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:30 from aggregator
03/09/2015 05:49:08.95 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:29 from aggregator
03/09/2015 05:49:08.75 <Info:vlan.dbg.info> Slot-1: Port 2:53 is Down, remove from aggregator 1:53
03/09/2015 05:49:08.71 <Info:vlan.dbg.info> Slot-1: Port 2:30 is Down, remove from aggregator 2:29
03/09/2015 05:49:08.71 <Info:vlan.dbg.info> Slot-1: Port 2:29 is Down, remove from aggregator 2:29
03/09/2015 05:49:08.59 <Warn:DM.Warning> Slot-1: BACKUP NODE (Slot-2) DOWN
03/09/2015 05:49:08.23 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 05:49:08.23 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 05:49:08.22 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 05:49:08.22 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link down.
03/09/2015 05:49:08.14 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 05:49:08.14 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 05:49:08.00 <Warn:DM.Warning> Slot-1: BACKUP is NOT in SYNC
03/09/2015 05:48:52.16 <Info:AAA.LogSsh> Slot-1: Msg from Backup : 1375 of 1375 bytes written to SSH System Config
03/09/2015 05:48:36.79 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:30 to aggregator
03/09/2015 05:48:36.79 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:29 to aggregator
03/09/2015 05:48:35.01 <Info:LACP.AddPortToAggr> Slot-1: Add port 2:53 to aggregator
03/09/2015 05:48:33.86 <Info:HAL.Sys.Info> Slot-1: Input voltage to  in slot 2 is on. Output enabled.
03/09/2015 05:48:33.86 <Info:HAL.Sys.Info> Slot-1:  in slot 2 is present.
03/09/2015 05:48:18.15 <Info:AAA.LogSsh> Slot-1: Msg from Backup : Loaded Private Key of size 1375 from System
03/09/2015 05:48:07.85 <Info:vlan.dbg.info> Slot-1: Media SF+_SR is inserted into Port 2:53
03/09/2015 05:48:06.55 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is operational
03/09/2015 05:47:48.89 <Warn:cm.configNotInSync> Slot-1: Backup node has different configuration files than primary node. Auto configuration file synchronization will be performed.
03/09/2015 05:47:13.08 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is inserted
03/09/2015 05:47:12.59 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 05:47:12.59 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link up at 10Gbps.
03/09/2015 05:47:04.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 05:47:04.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link down.
03/09/2015 05:47:03.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 05:47:03.24 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link up at 10Gbps.
03/09/2015 05:47:00.78 <Info:HAL.Port.Info> Slot-1: Stacking port 1:1 link up at 10Gbps.
03/09/2015 05:46:59.94 <Info:HAL.Port.Info> Slot-1: Stacking port 1:2 link up at 10Gbps.
03/09/2015 05:44:17.08 <Info:HAL.Sys.Info> Slot-1: EDPS-300AB A-S6 in slot 2 is disconnected.
03/09/2015 05:44:17.07 <Info:HAL.Sys.Info> Slot-1: EDPS-300AB A-S6 in slot 2 is disconnected.
03/09/2015 05:44:14.63 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 05:44:14.63 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 05:44:13.29 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 05:44:13.29 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link down.
03/09/2015 05:44:13.24 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 05:44:13.24 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 05:44:13.24 <Info:HAL.Port.Info> Slot-1: Stacking port 1:2 link down.
03/09/2015 05:44:13.24 <Info:HAL.Port.Info> Slot-1: Stacking port 1:1 link down.
03/09/2015 05:44:10.07 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is inserted
03/09/2015 05:44:08.29 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link up at 10Gbps.
03/09/2015 05:44:08.28 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link up at 10Gbps.
03/09/2015 05:44:06.65 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:53 from aggregator
03/09/2015 05:44:06.64 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:30 from aggregator
03/09/2015 05:44:06.64 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:29 from aggregator
03/09/2015 05:44:06.64 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:8 from aggregator
03/09/2015 05:44:06.64 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:7 from aggregator
03/09/2015 05:44:06.64 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:6 from aggregator
03/09/2015 05:44:06.64 <Info:LACP.RemPortFromAggr> Slot-1: Remove port 2:5 from aggregator
03/09/2015 05:44:06.17 <Info:vlan.dbg.info> Slot-1: Port 2:53 is Down, remove from aggregator 1:53
03/09/2015 05:44:06.16 <Info:vlan.dbg.info> Slot-1: Port 2:30 is Down, remove from aggregator 2:29
03/09/2015 05:44:06.16 <Info:vlan.dbg.info> Slot-1: Port 2:29 is Down, remove from aggregator 2:29
03/09/2015 05:44:06.13 <Info:vlan.dbg.info> Slot-1: Port 2:8 is Down, remove from aggregator 2:5
03/09/2015 05:44:06.12 <Info:vlan.dbg.info> Slot-1: Port 2:7 is Down, remove from aggregator 2:5
03/09/2015 05:44:06.12 <Info:vlan.dbg.info> Slot-1: Port 2:6 is Down, remove from aggregator 2:5
03/09/2015 05:44:06.12 <Info:vlan.dbg.info> Slot-1: Port 2:5 is Down, remove from aggregator 2:5
03/09/2015 05:44:06.04 <Warn:DM.Warning> Slot-1: BACKUP NODE (Slot-2) DOWN
03/09/2015 05:44:05.76 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 05:44:05.76 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
03/09/2015 05:44:05.75 <Info:HAL.Port.Info> Slot-1: Stacking port 2:2 link down.
03/09/2015 05:44:05.75 <Info:HAL.Port.Info> Slot-1: Stacking port 2:1 link down.
03/09/2015 05:44:05.69 <Warn:DM.Warning> Slot-1: BACKUP is NOT in SYNC
03/09/2015 05:44:05.59 <Info:HAL.Card.Info> Slot-1: Slot-2 down, resetting all TCP connections to it
03/09/2015 05:44:05.59 <Info:HAL.Card.Info> Slot-1: Module in Slot-2 is removed
Photo of Martin Flammia
Martin Flammia
  • 6,128 Points 5k badge 2x thumb
Posted 4 years ago
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
Martin,
First, what version of code and can you send me the output of "show switch" and "show ver" ??
How long have these been in service?
Bill
Martin Flammia
Hi Bill,
I don't have a current show version and show switch as I'm not currently on site but can update tomorrow but below is what they where before we upgraded them to 15.6.2.
The commands taken before upgrade are as follows:
-> show version
Switch      : 800538-00-02 1336N-42383 Rev 2.0 BootROM: 2.0.1.7    IMG: 12.5.4.5
SS-B-1      : 800384-00-01 1404N-40552 Rev 1.0
PSU-1       : NONE NONE NONE Rev 0.0
PSU-2       : EDPS-300AB A-S9 800515-00-03 1339E-40304 Rev 0.0
Image   : ExtremeXOS version 12.5.4.5 v1254b5 by release-manager
          on Tue Jun 28 10:10:40 PDT 2011
BootROM : 2.0.1.7
Diagnostics : 2.10
-> show switch
SysName:          X460-48t
SysLocation:
SysContact:       support@extremenetworks.com, +1 888 257 3000
System MAC:       00:04:96:8B:E8:3B
System Type:      X460-48t
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
System Watchdog:  Enabled
Current Time:     Wed Feb 18 22:18:55 2015
Timezone:         [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time:        Wed Feb 18 22:04:36 2015
Boot Count:       16
Next Reboot:      None scheduled
System UpTime:    14 minutes 19 seconds
Current State:    OPERATIONAL
Image Selected:   primary
Image Booted:     primary
Primary ver:      12.5.4.5
Secondary ver:    12.5.4.5
Config Selected:  NONE
Config Booted:    Factory Default
Many thanks.
Martin Flammia
Hi Bill,
Sorry, forgot to answer your other question. These have been in service since the weekend and have been experiencing problems since then.
Before there was a mixture of x460 and 400's, but none of them stacked. Was running a mixture of Extremeware and EXOS, but as I said, no stacking.
From a logical level the design now looks like a single link end to end using stacking and lags, so there is no spanning tree configured.
Many thanks,
Martin
Martin,
So you are on 15.6 now?  Have you opened a case with TAC on this yet?
Bill
Martin Flammia
Hi Bill,
That's correct. Unfortunately the GTAC process is going to be slow and difficult, which I can explain offline if you need to know more.
I'm hoping to get some quick answers or some things I can try, any logging I can turn on to capture the issue, any known bugs, recommend versions of firmware etc
That type of thing would be really appreciated.
Many thanks,
Martin
Martin,
Of course... I think I found you in our system, I will email you offline to get the details. If you don't get an email from me in the next hour let me know.
Bill
Photo of Ian Worms
Ian Worms
  • 422 Points 250 badge 2x thumb
Hi Martin,
I am having the same issue, just wanted to check what the out come from Extreme TAC was. If possible could you provide some type of feedback.
Thanks
Ian
Martin Flammia
  • 6,108 Points 5k badge 2x thumb
Hi Ian, the resolution was to configure a debounce timer against all the stacking ports.
You can find the resolution here https://gtacknowledge.extremenetworks.com/articles/Solution/Native-stack-links-are-flapping-on-Summi...
Cheers.
