Module on Matrix X 16 CPU load 100%
  • Problem
  • Updated 3 years ago
  • Solved
Hello guys,
We have a Matrix X 16-slot. On one of the modules we received the following messages:
WARNING: CPU utilization (100.0%) has exceeded the monitored threshold limit (80.0%)
After that all the ports on the module stopped working.
The module is 8 Port XFP GBIC 10 Gigabit Ethernet. After the module was reseated the problem was gone.
These were the processes on the module
Name              ProcID   15 Sec    1 min     5 min
     domainlink       7     0.26     0.28      0.25
                 dlm      10   131.80   131.71    132.85
                 ess      13    41.60    35.60     20.61
         fabmIom      14     6.20     6.38      6.18
                 fem      15    14.13    16.08     17.56
I could not find any information about these processes. Has anyone seen this problem or should i open GTAC case
Photo of Tsenislav Nakov
Tsenislav Nakov
  • 132 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Rainer Adam
Rainer Adam
  • 874 Points 500 badge 2x thumb
Do you use CA-Spectrum maybe for polling the devices? In a number of cases the last 15 years of my business Spectrum makes such an issue or was the major reason for it (reboot's of E1 switches for example).
Tsenislav Nakov
Hello Adam,
Thanks for the quick reply. CA-Spectrum is used. Is it possible that only one module got 100% CPU utilization in this case
Rainer Adam
What version do you use on your X-Series? There exists also a 497 days issue with release 2.0.2.0 or 2.0.2.1 with a known spanningtree issue.
Tsenislav Nakov
The version is 2.0.3.0
Rainer Adam
I would recommend you to open a TAC case for this and if exists please attache the core dump file(s).
