monitor A4 temperature in netsight
  • Question
  • Updated 4 months ago
  • Answered
Hello
How can I monitor the A4-series switch temperature in netsight?
Also How can I read the temperature on other SNMP client?
A4 firmware 06.81.02.0007
Netsight 4.0.1.34
Photo of Alberto Cornejo
Alberto Cornejo
  • 80 Points 75 badge 2x thumb
Posted 5 months ago
Photo of ar
ar
  • 602 Points 500 badge 2x thumb
Hello Alberto
I'm not sure but I think it's not possible to get this information via snmp or cli.
But if you find out how this will work I would like to know it, too.
Photo of Bob Maheu
Bob Maheu, Employee
  • 1,040 Points 1k badge 2x thumb
Hello Alberto,
You will not be able to get the actual temperature from the A4, but you can get a status to see if it is in a normal range.  The OID to query would be:
chEnvAmbientStatus=1.3.6.1.4.1.52.4.1.1.8.1.2
Which has values of:
chEnvAmbientStatus OBJECT-TYPE SYNTAX Integer {
unknown(1), cold(2), cool(3), normal(4), warm(5), hot(6), inoperative(7) }
Alberto Cornejo
Dear Bob
Thank you for your answere, but I have try to read with this OID code and don ́t get NULL value, do you know another code to try?
Photo of ar
ar
Hi Bob,
thanks.
