Monitoring BGP
  • Question
  • Updated 3 years ago
  • Answered
Hello guys!
We are trying to monitor a BGP session in a SW extreme(X450). We use the command "snmpwalk" to validate the information regarding the OID of BGP, where it informs that there are 5 sessions. When we try to do a "snmpwalk" in a session more specific, it returns an error stating that the OID do not hesitate.
Any suggestion? XOS version is 15.2.1.5
Picture error bellow...
Photo of Tavares Belmont
Tavares Belmont
  • 638 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Andrew Maldonado
Andrew Maldonado, Extreme Alumnus
  • 2,302 Points 2k badge 2x thumb
Tavares,
Do we experience the same error when executing a SNMP get locally on the switch? The command would be "show snmp get 1.3.6.1.2.1.15.3.1.2.a.b.c.d" where a.b.c.d is the IP address of the BGP peer.
-Andrew
Tavares Belmont
Hi Andrew,
We have the same situation. when we put the command below, the error is the same.
mib_2.15.3.1.2.x.x.x.x = NO_SUCH_IINSTANCE_EXCEPTION
we realeased that the msg appear in zabbix too.
Tavares Belmont
yes i see,
but i found this command "configure snmpv3 add mib-view "name" subtree "oid" type excluded | included...
Its possible add subtree and use via snmv3? The website bellow show possibles OIDS and respective funcions too, on extreme switch juts works "show snmp get 1.3.6.1.2.1.15.2.0" = local AS and 1.0 BGP version, i created a ticket on TAC but until now anyone reply.
https://www.kernel.org/pub/software/admin/mon/contrib/monitors/bgp/bgp.monitor
Tavares,
I do not believe the "configure snmpv3 add mib-view" command will assist in this issue. Were you able to get a reply on the open ticket?
-Andrew
Tavares Belmont
Hello,
They told me that usually similar problems with this are usually only resolved with external intervention of the development area because the extreme not have these MIBs implemented in software, they closed the ticket on the grounds that other monitoring systems as Rigdline and Netsght work properly.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,294 Points 10k badge 2x thumb
Hi Tavares,
I found your case, and opened up a feature request for you. The case number for the feature request is 01126976.
-Brandon
Tavares Belmont
Thank you guys!
 "I've been in contact with the team and sustaining new tests were conducted regarding the monitoring via SNMP of BGP peers."
Example:
Note:
The MIB will respond values from 1 to 6 and will be manager function to convert it to the corresponding string:
Values 1: idle
                2: connect
                3: active
                4: OpenSent
                5: OpenConfirm
                6: established
The device can get that information based on "strings".
summitX460.8 # show snmp get-next 1.3.6.1.2.1.15.3.1.2
mib_2.15.3.1.2.10.10.10.1 = 6 (established)
Object                                 bgpPeerState
Main OID                            1.3.6.1.2.1.15.3.1.2
Peer 10.10.10.1 OID        .1.3.6.1.2.1.15.3.1.2.10.10.10.1
