More than one Portal Page on V2110 controller
  • Question
  • Updated 2 years ago
  • Answered
is there a possibility to setup more than one Captive Portal page on a V2110 Controller?
Challenge are two SSIDs on different VLANs in a Building where Guests and permanent residents should be separated and authenticate via different Captive Portals or Username password.
We have no NAC installed there
Photo of Peter Kulmbrein
Peter Kulmbrein
  • 1,176 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Paulo Francisco
Paulo Francisco, Employee
  • 1,312 Points 1k badge 2x thumb
Official Response
It depends what you mean by "Captive Portal". If you're referring to Integrated Guest Portal (where the user credentials database is the controller itself), then as Ronald mentions there is only one instance per controller.
However, the other  Captive Portal configurations (Internal Captive Portal [radius authentication of users], Guest Splash or full External Captive portals) don't have that limit. You can have a unique configuration per WLAN service.
For user authentication you'd need access to a Radius Server [ NAC or any other RADIUS server implementation]
