MPLS-TE with OSPF Inter-Area
  • Question
  • Updated 2 years ago
  • Answered
I have a problem  MPLS-TE with OSPF Inter-Area. Any one can share this problem? Is it support MPLS-TE with Multi-Area?
Photo of Ko Saw Gyi
Ko Saw Gyi
  • 192 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Hicks, Joe
Hicks, Joe, Employee
  • 190 Points 100 badge 2x thumb
If the lsp starts in one ospf area and finishes in a different one there is a bug. Bug is fixed in 21.1 and 16.2
Photo of Tayzar Lwin
Tayzar Lwin
  • 238 Points 100 badge 2x thumb
Still have problem on MPLS-TE with inter-area. We are using EXOS version 16.2.1.6. .
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
Hi Tayzar, could you please provide more details such as a topology and MPLS configuration?
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,598 Points 10k badge 2x thumb
just checking, did you look at 16.2 User Guide to see how the enhancement to allow path computation across areas works? Look at page 1265
Starting with ExtremeXOS 16.2, the path-computation keyword specifies computation strategy for calculating a path to the LSP destination. "full" requires the ingress node to full calculate a path to the LSP destination. "partial" allows the ingress node to calculate only part of the path to the LSP destination. In this case, it would be to the ABR, and the ABR would calculate the rest of the way (into the other area).
by default the setting is "full".
Tayzar Lwin
Hi Grosjean,
Thanks for your answer. We are not using RSVP-TE profiles. We create RSVP-TE path and just add to RSVP-TE lsp. RSVP-TE profiles didn't work with previous firmware 15.x.x versions and we get rid of using RSVP-TE profiles in our deployment.
Photo of Henrique
Henrique, Employee
