MPLS FAT Label
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Hello,
By reading this article http://packetpushers.net/fat-or-entropy-label/ I`ve been wondering if Extreme could implement something like that (FAT Label)?
Some l2vpn circuit are getting 10Gbps and the outer interfaces port channels aren`t handling it well.
Photo of Julian Eble
Julian Eble
  • 1,394 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,458 Points 10k badge 2x thumb
Hi Julian,
have looked at the GTAC Knowledge article Incorrect load sharing on MPLS P-node?
Erik
Photo of Henrique
Henrique, Employee
  • 10,302 Points 10k badge 2x thumb
(Edited)
Julian Eble
So, we`ve tried everything is possible to solve that, but none solved.
As the sharing only see one label carrying that huge traffic, it cannot load-balacing between the aggregates ports.
I think the only way to do that is by adding this on the mpls header (Entropy/Fat label).
https://tools.ietf.org/html/rfc6790
(Edited)
Photo of Korsovsky, Konstantin
Korsovsky, Konstantin, Employee
  • 810 Points 500 badge 2x thumb
Hi Julian,
 did you try to use "l2vpn sharing" feature?
Please check examples from discussion on a link below. It might help you to solve the problem.
https://community.extremenetworks.com/extreme/topics/load-balance-problem-using-vpls-as-transport
Keep in mind that that feature has some limitations:
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-are-limitations-for-Pseudowire-Label-Swi...
Julian Eble
Hello Konstantin,
It`s odd because I did the same thing in my lab and couldn`t get the same result. What version did you use in that test enviroment?
Another thing, is that I`m waiting for xos0066476 to be solved, isn`t save to use rsvp in the current working network.
When I started to test it I also failed and then I figured out that LSP sharing doesn't work with unknown unicast traffic:
https://gtacknowledge.extremenetworks.com/articles/Solution/Pseudowire-Label-Switch-Path-Load-Sharin...
So make sure that traffic which you trying to load-balance is bidirectional.
Julian Eble
Most of our traffic is one source/dest mac but has multiples source/dest IP unicast
some of these vpls has 15Gb.
Is there any problem of what kind of unicast traffic is? even if it`s just one mac and lsp will do the balancing?
I`ll give a new try to that in my lab..
(Edited)
Photo of Henrique
Henrique, Employee
Could you please share your network diagram and point where the balancing is not working as expected?
This will help us to have a better insight.
Thanks.
Julian Eble
Henrique,
The backbone isn`t load balancing.
A ticket was answered by you informing that behaviour(Unifique).
Houve a resposta informando a impossibilidade e referente ao uso de dois labels.
Queria apenas discutir a possibilidade e se isso poderia ser feito da parte de entropia e adição de label para o hash.
(Edited)
Photo of Henrique
Henrique, Employee
Hi Julian, I'm not sure if there is a roadmap to have "The Use of Entropy Labels in MPLS Forwarding" implemented.
I will check internally and let you know.
Photo of Henrique
Henrique, Employee
Hi Julian, currently there is no roadmap to have that feature implemented. I will let you know fi anything changes during the next months.
