MSM-A: Changing to watchdog warm reset mode
  • Question
  • Updated 2 years ago
  • Answered
Please I need the description  for the below log.
<Noti:EPM.UnexpctRebootDtect> MSM-A: Booting after System Failure. <Noti:EPM.wd_warm_reset> MSM-A: Changing to watchdog warm reset mode
Image   : ExtremeXOS version 15.4.2.8 v1542b8-patch1-3 by release-manager
          on Fri Sep 5 02:52:55 EDT 2014
Thanks
Photo of Kar Mah
Kar Mah
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,838 Points 5k badge 2x thumb
This could have been because of a power outage,.  Do you have any more logs?
Photo of Kar Mah
Kar Mah
Hi Thanks for your answer and below more log related to the issue.
the problem that after this log the switch has been restarted.
11/04/2016 07:10:43.78 <Info:SNMP.Master.InitDone> MSM-A: snmpMaster initialization complete
11/04/2016 07:10:43.49 <Info:DOSProt.Init> MSM-A: DOS protect application started successfully
11/04/2016 07:10:43.46 <Info:HAL.Card.Info> MSM-A: Module in Slot-5 is inserted
11/04/2016 07:10:42.42 <Info:HAL.Card.Info> MSM-A: Module in Slot-2 is inserted
11/04/2016 07:10:42.22 <Info:tftpd.info> MSM-A: **** tftpd started *****
11/04/2016 07:10:42.13 <Info:SNMP.Subagent.InitDone> MSM-A: snmpSubagent initialization complete
11/04/2016 07:10:41.67 <Info:telnetd.info> MSM-A: **** telnetd started *****
11/04/2016 07:10:41.51 <Info:HAL.Card.Info> MSM-A: Module in Slot-1 is inserted
11/04/2016 07:10:41.49 <Noti:DM.Notice> MSM-A: Node State[1] = INIT
11/04/2016 07:10:41.40 <Info:HAL.Sys.Info> MSM-A: Hal initialization done.
11/04/2016 07:10:41.09 <Info:nl.init> MSM-A: Network Login framework has been initialized
11/04/2016 07:10:40.56 <Info:HAL.Card.Info> MSM-A: Module in MSM-A is inserted
11/04/2016 07:10:39.99 <Info:HAL.Sys.Info> MSM-A: Module in power supply slot 3 is inserted.
11/04/2016 07:10:39.86 <Info:HAL.Sys.Info> MSM-A: Module in power supply slot 2 is inserted.
11/04/2016 07:10:39.69 <Info:HAL.Sys.Info> MSM-A: Module in power supply slot 1 is inserted.
11/04/2016 07:10:38.91 <Info:HAL.Sys.Info> MSM-A: Switch is operational
11/04/2016 07:10:38.59 <Info:HAL.Sys.Info> MSM-A: Switch is operational
11/04/2016 07:10:38.42 <Noti:HAL.Sys.Notice> MSM-A: Module in fan slot 1 is inserted
11/04/2016 07:10:38.06 <Info:telnetd.info> MSM-A: telnetd listening on port 23
11/04/2016 07:10:37.70 <Info:HAL.Sys.Info> MSM-A: Starting hal initialization ....
11/04/2016 07:10:33.44 <Noti:DM.Notice> MSM-A: DM started
11/04/2016 07:10:33.40 <Noti:NM.StrtProc> MSM-A: The Node Manager (NM) has started processing.
11/04/2016 07:10:32.66 <Noti:EPM.start> MSM-A: EPM Started
11/04/2016 07:10:32.65 <Noti:EPM.UnexpctRebootDtect> MSM-A: Booting after System Failure.
11/04/2016 07:10:31.49 <Noti:EPM.wd_warm_reset> MSM-A: Changing to watchdog warm reset mode
It looks like a power issue from the logs.  There's not much to go on.  Are there better logs in the "show log messages nvram" logs?
Photo of Kar Mah
Kar Mah
Thanks a lot I try to check the power issue
thanks again for your support
Photo of christopher madison
christopher madison
  • 360 Points 250 badge 2x thumb
we have been seeing this on and off for about a year now. we too thought it was power issues. we have since deployed UPS's that show no power issues. other extreme switches hooked up to the same UPS did not reboot at the same time. we have just updated to the newer software. 16.1.3.6 patch1-11, but are still having the issue. do you have a gtac ticket open? I am opening one now for a switch that just had a reboot.
Photo of EtherMAN
EtherMAN, Embassador
  • 6,456 Points 5k badge 2x thumb
Did you see if there was a system dump file... show debug system-dump... If this is a hardware or process problem that brought about the instability that caused the reboot then it would generate a file.  Also do you have dual MSM's if so and A is bad it should fail over to B and not reboot system.
