MSTP in a rapidly changing environment
  • Problem
  • Updated 2 years ago
  • Solved
I'm having a hard time integrating MSTP in my environment.
Basically it's a rapidly changing environment where projects change on a weekly, sometimes even daily basis.
This means that adding VLANs and creating new networks and firewall policies is a very frequent task.
The topology consists of a pair of core switches (MLAG peers) and lots of edge switches (20+). All of those belong to the same MSTP region.
What happens is that often I have to add another VLAN/network for a particular area (covered by a particular edge switch) and since I want to have it protected by STP i end up with a very time consuming task.
Problem is, when I create another VLAN I have to make MSTP digest consistent throughout my whole topology.
That means I have to go through all of core and ALL of my edge switches (20-30 of them) and create the VLAN, auto-bind it to a MSTI and finally even add it to the uplink.
Basically it's such an overhead I'm almost thinking of binding only permanenly existing VLANs (e.g. infrastructure, sales...) and leave the project VLANs outside of STP completely.
Creating a script to automate the config at least on the edge switches seems very dangerous...
I hate to say this but something like this is a breeze on cisco.
There you can manage and propagate VLANs with VTP (yes i know of the shortcomings...); MSTP can be configured in advance identically everywhere since VLANs don't have to _exist_ in order to be defined in MSTI config.
I desperately need some advice or suggestion how to reduce the overhead this imposes...
To sum it up,
Problem 1 - is there really no way to make MSTP config consistent everywhere before VLANs are even created on the switch? E.g. configure mstp to bind vlans 1-999 to MSTI before all of those VLANs even exist - just so that the digest matches everywhere.
Problem 2 - is there really no way to simplify VLAN propagation? MVRP comes really close but it's meant only for AVB. Since it's impossible to manually adding ports to dynamically created VLAN it's useless in this scenario.
If those problems aren't solved, how do you guys cope?
Thanks in advance,
Regards,
Vladimir
Photo of vobelic
vobelic
  • 362 Points 250 badge 2x thumb
Posted 2 years ago
Photo of David Coglianese
David Coglianese, Embassador
  • 7,208 Points 5k badge 2x thumb
What is preventing you from using elrp?
The configuration is much simpler and it works great.
Photo of vobelic
vobelic
Core and some of the edge switches are extreme, but edge varies so i'd keep it vendor free.
(Edited)
That makes sense. Unfortunately stp is not my bag, best of luck.
Photo of Dave Hammers
Dave Hammers, Dir SW Engineering
  • 3,722 Points 3k badge 2x thumb
Photo of vobelic
vobelic
I've just gone from 15.5 to 16.1.
Also most of my extremes are G1, so they won't be going 21.x very soon...
Photo of Brian Anderson
Brian Anderson
  • 626 Points 500 badge 2x thumb
How about adding a tagged vlan to all your end system ports, such as STP_VLAN? You can setup that one vlan to do spanning tree and then you can leave it alone, and add and delete other vlans off of the port, without affecting your STP config.
I like that idea,
That's like the ELRP spanning tree config.
Photo of vobelic
vobelic
On which side you mean? The core or on the edge switches?
In any case, I assume you mean to abandon MSTP and just use plain STP with only one VLAN participating?
I guess that defeats the whole concept then.
Brian Anderson
On the edge.
Do you currently use MSTP to load balance vlans across redundant links, or need different root?
Photo of vobelic
vobelic
There's a few hundred vlans we manage (small number of access ports per vlan tho) so MSTP makes most sense in terms of reduced cpu footprint.
Also, different root is desirable (currently not needed) for cases when integrating dedicated project equipment into existing infrastructure.
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,486 Points 10k badge 2x thumb
One note: Using one STP vlan will not work with EXOS's implementation of STP. EXOS always blocks on a VPIF (VLAN/port interface), even with 802.1d and 802.1w  STP modes. Because of this, any vlans not added to the spanning tree domain will not be blocked, even if the port is not in the forwarding state.
Brian Anderson
Even with Edge-safeguard enabled?  Below is a sample config of what I've used.
create vlan "STPVlan"configure vlan STPVlan tag 1111
configure vlan STPVlan add ports all tagged
configure mstp region STPVlan
configure stpd s0 delete vlan default ports all
disable stpd s0 auto-bind vlan default
configure stpd s0 mode mstp cist
create stpd STPVlan_stm
configure stpd STPVlan_stm mode mstp msti 1
configure stpd STPVlan_stm add vlan STPVlan ports all dot1d
configure stpd s0 ports mode dot1d 1:1-52,2:1-24
configure stpd s0 ports cost auto 1:1-52,2:1-24
configure stpd s0 ports link-type edge 1:1-48,2:1-24
configure stpd s0 ports edge-safeguard enable 1:1-48,2:1-24 recovery-timeout 60
configure stpd s0 ports bpdu-restrict enable 1:1-48,2:1-24 recovery-timeout 60
enable stpd s0 ports all
configure stpd STPVlan_stm ports mode dot1d 1:1-52,2:1-24
configure stpd STPVlan_stm ports cost auto 1:1-52,2:1-24
configure stpd STPVlan_stm ports edge-safeguard enable 1:1-48,2:1-24 recovery-timeout 60
configure stpd STPVlan_stm ports bpdu-restrict enable 1:1-48,2:1-24 recovery-timeout 60
enable stpd STPVlan_stm ports all
enable stpd s0
Photo of vobelic
vobelic
Hypothetically, let's say I were to have all extreme hw and decide on MLAG and ELRP.
I'm going off topic here, so If needed i'll open another discussion.
Since access port VLAN membership changes frequently, I guess ELRP has to be configured for all VLANs. Having a dummy vlan for ELRP doesn't seem like a solution since ELRP frames have to be untagged when leaving the access port? Tagged ELRP frames would be dropped by customer equipment and loops wouldn't be detected.
First, what about CPU footprint on ELRP for few hundred VLANs?
Second, is it planned to implement the vlan range configuration for elrp?
Even with 16.1.3 sw it's not possible to simply run "configure elrp-client periodic vlan <1-4095> .... ".
I was really overjoyed when I upgraded to 16.1+ and discovered this "enhancement".
On a side note..Interesting how nobody asked when I mentioned MLAG and STP in the same sentence...
I just read in the documentation that STP and MLAG ports don't go together.
Basically i'd be stuck with multiple (M)STP isolated segments (on each edge sw).
Photo of James A
James A, Embassador
  • 7,338 Points 5k badge 2x thumb
Do you need MSTP to the edge, or could you just have it at the core and then have STP at the edge?
If we create a version of ezspantree that works with 16.1, would that solve the problem? It would function the same way as https://github.com/extremenetworks/EXOS_Apps/tree/master/EZ_SpanningTree
