Multi IPs per VLAN Interface
  • Question
  • Updated 3 years ago
  • Answered
Is it possible to have more than one Ip per VLAN Interface? It is something like IP aliasing.
Photo of Mrxlazuardin
Mrxlazuardin
  • 1,534 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Parthiban V
Parthiban V, Employee
  • 618 Points 500 badge 2x thumb
Yes you can configure multiple ipaddress for a single vlan.
You need to add it as secondary ipaddress.
Example:
configure v1 ipaddress 10.1.1.1/24
configure v1 add secondary-ipaddress 20.1.1.1/24
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,536 Points 3k badge 2x thumb
Hi ,
Yes it’s possible to configure more than one IP per vlan and this is  called IP Multinetting.
Please refer - EXOS_User_Guide_16_1.pdf on page number # 1332.
check and let us know if you have any questions.
Thanks,
Suresh.B
Photo of Drew C.
Drew C., Community Manager
  • 40,586 Points 20k badge 2x thumb
Here's a link to the HTML version of the IPv4 Multinetting chapter from the EXOS User Guide:  http://documentation.extremenetworks.com/exos/EXOS_All/IPUnicast/c_ipv4-multinetting.shtml
Mrxlazuardin
If I do DHCP relaying, will secondary IP do DHCP relaying too? I want to expand my exhausted DHCP pool of a VLAN but I cannot just resize the subnet since the adjacent subnet has been used. So I think I can do it by adding secondary IPs with different subnet in same VLAN so the DHCP clients will randomly (or load balanced) get the IPs from primary and secondary subnets. Any tough?
