multi ring eaps gateway
  • Question
  • Updated 3 years ago
  • Answered
Hi, need to ask about EAPS .
Can two EAPS ring used the single Gateway. If can, how to configure it? use active-active VRRP or other topology?
Example:
Eaps ring A default gateway 192.168.1.2/24
Eaps ring B default gateway 192.168.1.3/24
Can we use Virtual IP 192.168.1.1/24 as gateway. Thank you for help
Photo of Carloze
Carloze
  • 70 Points
Posted 3 years ago
Photo of Lane, Mike
Lane, Mike, Employee
  • 904 Points 500 badge 2x thumb
This is definitely possible.  As EAPS is protecting only the L2 topology, a redundant gateway will work.  The questions that needs to be asked is whether Active-Active VRRP would work as well as what would the fail/recovery behavior be?
This can be easily tested, even in a production environment, as long as you are careful to isolate to just one test VLAN with one or two hosts and are prepared to recover from a potential loop in that VLAN.
There is no special configuration for the combination of EAPS and VRRP, it is all covered in the User Guide.
