Multicast between SSID(vlan)
  • Question
  • Updated 8 months ago
  • Answered
Hi!!!
i have a chromecast into SSID(vlanA) but need access from SSID(vlanB or C) Need set something into AP7522 or al work about multicast is in the switch. I have switch DELL N3000 series.
Thx.
Photo of Rodrigo Cortes
Rodrigo Cortes
  • 490 Points 250 badge 2x thumb
Posted 8 months ago
Photo of Darrel Rhodes
Darrel Rhodes, Employee
  • 1,116 Points 1k badge 2x thumb
Hi Rodrigo, you need to enable client-to-client communication on the WiNG network for chromecast to work. Do you have a centralised controller or are you running an AP as a virtual controller?
Also your VLANs will need to route multcast across the approrpriate VLANs.  Not Dell-specific but this might help:  https://community.extremenetworks.com/extreme/topics/setting_up_inter_vlan_multicast_routing
Thanks,
Darrel.
Rodrigo Cortes
Hi Darrel,
i have a VAP. All client into the same SSID or vlan see the chromcast and client-to-client are enable(verified). But need some extra to work with other SSID? This others SSID they are not connected to each other like guest
And reading the doc now :)
Thx.
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hi Rodigo,
Kindly add the following article for your reference.
https://gtacknowledge.extremenetworks.com/articles/Q_A/why-Chromecast-is-blocked-by-a-Wing-AP
Best regards,
Bin
Rodrigo Cortes
Hi Bin!
I have the next scenario working. 2 groups of switch in stack mode. Both have AP7522 connected and working. Both groups are interconnected by LACP fiber module. All AP7522 are in the same group and have one working like VAP.
both groups share 3 principal vlan. LAN, Wifi Mobile, Wifi Guest.
Chromecast are connected to LAN for access from PC/Notebook Corporative and working fine.
How to permit to the other SSID access to chromecast? is possible?
Thx.
Photo of Bin
Bin, Employee
Hi Rodrigo,
Very sorry. I do not sure this scenario is possible or not. I did not do the test before.
However, as long as chromecast supports bonjour advertisements we can fit with regular bounjour config. See i.e. this for details. Service name is _googlecast._tcp.local.
Kindly request you could your test on this post.
Many thanks in advanced.
Bin
Rodrigo Cortes
Hi Bin!!!
Reading some documents, detect that they mention bonjour service. Based on this review, activate the options in the AP and voila! I could see the chromecast from other WIFI. In my case need put some rules into FW for pass http port 8008-8009.
The doc from you have the same but in the last firmware the chromecast parameter is a option.
Thx All!
Photo of Bin
Bin, Employee
Hello Rodrigo,
Thank you for posting your result!!!
I could share your story with other customers.
I also just checked that we added chromecast in WiNG 5.9.
Best regards,
Bin
Rodrigo Cortes
Hi Bin!
in my case:
bonjour-gw-forwarding-policy Chromecast
 forward-bonjour-response from-vlans 10,1000 to-vlans 37 rule-index 1
bonjour-gw-discovery-policy Chromecast
 allow-service Chromecast local service-vlans 10,37,1000
and share :D
Photo of Bin
Bin, Employee
Hi Rodrigo,
Thank you so much for sharing your configuration in detail.
Best regards,
Bin
