Multicast problem: Ingress vif not found
  • Problem
  • Updated 3 years ago
I found this warning on several switches:
<Warn:Kern.Card.Warning> Slot-1: exosmc: ip_mc_handle_msdp_data:2038: MC: Ingress vif not found
Does anyone know what this means?
We have software versions 15.3.1.4 patch1-7 and 15.5.2.9 patch1-5
Photo of TuomasR
TuomasR
  • 70 Points
Posted 4 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
15.3.1.4patch1-7 is a buggy exos removed
From
Extreme website .
Please help yourself to upgrade to stable versions 15.3.1.4 latest patch
Photo of Esa Kuusisto
Esa Kuusisto
  • 310 Points 250 badge 2x thumb
Known error. I worked with TAC long time ago with this case. I am not sure which version includes the fix.
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
This issue should be present due to some bug.
Photo of Roxelchen
Roxelchen
  • 90 Points 75 badge 2x thumb
In which version is this fixed?
Esa Kuusisto
Could not find which xos<number> was assigned to bug. My old case number was 4-4332665701
Photo of OscarK
OscarK, ESE
  • 7,912 Points 5k badge 2x thumb
I think this might be CR xos0055945, fixed in 15.7.1.
If translation/network VLAN receives multicast packet with member/subscriber vlan tag, then switch throws error message "exosmc: ip_mc_handle_msdp_data:2038: MC: Ingress vif not found”.
Depending if you use vlan translation or private vlans this might be applicable.
Esa Kuusisto
I hope that fix will be in 15.3 version.Several older x650 newest version what can be installed is 15.3
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,488 Points 10k badge 2x thumb
It looks like a fix is not currently scoped for 15.3. However, if you are running into this issue on an X650, I would suggest opening a case with GTAC or contacting your account team so we can request a patch in 15.3 as well.
Esa Kuusisto
Funny :) I opened this case with those X650 switches. Well I will open new case. Still so far this looks like cosmetic issue.
